Dec 29, 2009 - 8:31 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
when i brake hard, e-brake light comes on and goes back off when car weight shifts.
sometimes when the car shifts weight when changing from 1st to 2nd or in 2nd gear and releasing the gas pedal, it lights on too. is this bad and how could i fix this? thanks -------------------- God made man....
Everything else... Made in China ![]() |
Dec 29, 2009 - 9:03 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '06 From Los Alamos, NM Currently Offline Reputation: 1 (100%) |
check your brake fluid
This post has been edited by spolski07: Dec 31, 2009 - 10:55 AM -------------------- 2015 Subaru WRX. World Rally Blue/Black
2001 Honda S2000. Spa Yellow/Black |
Dec 29, 2009 - 9:19 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 29, 2009 - 9:49 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Yep, you need to fill up your brake fluid.
Dec 29, 2009 - 10:04 PM
Enthusiast ![]() ![]() Joined Apr 20, '09 Currently Offline Reputation: 4 (100%) |
^---- agree with above. I actually posted a thread a while ago saying I was having the same problem, topped off the brake fluid res and the problem went away.
-------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Dec 29, 2009 - 11:39 PM
its full
Dec 30, 2009 - 5:57 PM
Enthusiast ![]() ![]() Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
check your break fluid Yep, you need to fill up your brake fluid. Why does everybody just say this? Sure the level can be on the low side, but you aren't telling why that will be! Mostly because of worn brake pads, so the pistons are way out of the caliper cylinders. So check your pads before you will top the fluid of, otherwise it will be a huge mess under the hood when you replace the pads another time!!! -------------------- JDM ST205
Dec 30, 2009 - 7:17 PM
True, you should check your pads. As your pads wear down they need to be pushed farther out, making the fluid levels in your res read low. If you replace the pads and your fluid levels are still at low then you need to look into a fluid leak somewhere.
And if you say it's already full then I would go ahead and replace the pads now and have your rotors turned. Put the car on jack stands and take the rotors some place to be turned, and while everything is off go ahead and toss on some braided lines on there. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Dec 30, 2009 - 7:45 PM
True, you should check your pads. As your pads wear down they need to be pushed farther out, making the fluid levels in your res read low. If you replace the pads and your fluid levels are still at low then you need to look into a fluid leak somewhere. And if you say it's already full then I would go ahead and replace the pads now and have your rotors turned. Put the car on jack stands and take the rotors some place to be turned, and while everything is off go ahead and toss on some braided lines on there. what do you mean by rotors turned? is that the same as resurfacing it? i had new rotors installed on july '08 nad the brake pads as well. i will try to check them again to make sure. i just dont quite get this but is the ebrake mech/system different from the rear brakes? -------------------- God made man....
Dec 30, 2009 - 8:34 PM
Turned=resurfacing
And I believe the e-brake is a drum-in-disc assembly. When you apply the e-brake it pushes a drum-like brake shoe onto the inside of your rear rotors. When you slip the rear rotors off you'll see what I mean. Here is a diagram: ![]() -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Dec 30, 2009 - 10:48 PM
alright thanks! will check after the rain
Dec 30, 2009 - 11:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
if you check all that stuff out and the light still comes on. Get a wiring diagram and trace out what ever powers up that light and check that out.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Jan 6, 2010 - 11:19 PM
Did you ever get this figured out? I would've also said to check and make sure your brake fluid level is correct. Next step I'd take is to bleed the brake lines, make sure there's no air in them, and then add whatever amount to the fluid reservoir to make sure it's still correct. If that still doesn't resolve the issue, and your brake pads are good, I'd probably start considering any possible failure in the brake master cylinder.
Jan 6, 2010 - 11:41 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Man, that happens to me too. When I brake hard, the brake light comes on.
Jan 7, 2010 - 12:54 AM
We used to have a Ford Exploder that would display the E-Brake light if you slammed on the brakes. It had something to do with the ABS. Not a likely culprit in this instance since you said it comes on sometimes when you shift, but you never know. Just thought I'd throw my two cents in.
Jan 7, 2010 - 2:18 AM
Did you ever get this figured out? I would've also said to check and make sure your brake fluid level is correct. Next step I'd take is to bleed the brake lines, make sure there's no air in them, and then add whatever amount to the fluid reservoir to make sure it's still correct. If that still doesn't resolve the issue, and your brake pads are good, I'd probably start considering any possible failure in the brake master cylinder. not yet. ill try to bleed it over the weekend. Man, that happens to me too. When I brake hard, the brake light comes on. braking hard and shifting between 1-2-3 gear. i remember last year, this happened already until the e-brake light wont go off. then after driving in the rain, it went away which i find it weird. We used to have a Ford Exploder that would display the E-Brake light if you slammed on the brakes. It had something to do with the ABS. Not a likely culprit in this instance since you said it comes on sometimes when you shift, but you never know. Just thought I'd throw my two cents in. mine doesnt have an ABS. its something that triggers it when a lot of weight shifts to the front -------------------- God made man....
Jan 7, 2010 - 12:05 PM
I still think it has something to do with your brake master cylinder, you're POSITIVE the fluid level is correct? There's two lines, the bottom line is the minimum amount needed and the top is the Full line. Make sure your parked on level ground and double check that fluid level, I really really think that's all it is. I think there's a little floaty thing in there, too, maybe your floaty thing is stuck and it's triggering the fluid level sensor? If it's not that, then it's gotta be that your brake master cylinder is failing and putting a heavier load on it is maxing out its failing hydraulic system.
Jan 7, 2010 - 2:17 PM
ill try to siphon some out and refill.
Jan 7, 2010 - 8:14 PM
Don't syphon it out, bleed the brakes!
| Lo-Fi Version | Time is now: July 30th, 2026 - 6:06 PM |
