> 3SGTE Rods and Pistons (stock specs), Looking for aftermarket brand with stock specs
post Dec 29, 2009 - 10:40 PM
nemesis
Joined Jan 14, '06
Hey 6GC friends,
It's been a minute since I have been on here. Happy new year to all of you.
Regarding the pistons for the 3SGTE All-trac motor: is 8.5:1 the stock compression?
The JE Pistons/Rods combo I find on ebay has a compression ration of 9.0:1
See link below:
http://cgi.ebay.com/ebaymotors/JE-Pistons-...2#ht_2627wt_860
p.s. Does anyone know where I can obtain the stock specs on both the rods and pistons for the 3SGTE?
Thanks in advance!
I drive a Celica. Anything "less" is just a car!
post Dec 29, 2009 - 11:02 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
Manufacturer: Toyota
Model: ST185
Year: 1990-93
L/CID/VIN: 2.0/122/3SGTE
# of cylinders: 4
Bore & Stroke: 3.3858-3.3870" (85.999-86.03MM) x 3.386" (86.004MM)
Compression Ratio: 8.8:1 (gen 1 and 3, 8.5:1)
Firing Order: 1-3-4-2
Cylinder Head
Thickness: 4.6950-4.6990" (119.253-119.355 MM)
Maximum Warpage: .008" Overall (.203 MM)
OHC Bore Data: 1.0614-1.0620" (26.96-26.975 MM)
Valve Info
Installed Stem Height (Intake): 1.4600-1.4850"
Installed Stem Height (Exhaust): 1.4700-1.4950"
Stem Diameter (Intake): .2346-.2352" (5.959-5.974 MM)
Stem Diameter (Exhaust): .2344-.2350" (5.954-5.969 MM)
Total Length (Inatke): 4.12600-4.1535" (104.8-105.499 MM)
Total Length (Exhaust): 3.8917-3.9193" (98.849-99.55 MM)
Angle (Intake & Exhaust): 44.5 degrees
Margin (Intake & Exhaust): .020" Min. (.508 MM)
Valve Guide Info
Guide Height (Intake & Exhaust): .323-.339" (8.204-8.611 MM)
Guide Clearance (Intake): .0010-.0023" (.025-.058 MM)
Guide Clearance (Exhaust): .0012-.0025" (.03-.064 MM)
Spring Info
Free Length (Intake & Exhaust): 1.749" (44.425 MM)
Installed Height (Intake & Exhaust): 1.354" (34.392 MM)
Closed Test Press (Intake & Exhaust): 45-53# @ 1.354"
Valve Seat Info
Seat Width (Intake & Exhaust): .039-.055" (.991-1.397 MM)
Seat Angle (Intake & Exhaust): 45 degrees
Valve Lash Info
Intake Valve Lash: .006-.010" Cold
Exhaust Valve Lash: .008-.012" Cold
Cylinder Head Torque Spec. 36 FT/LBS, + 90 degrees
Block Info
Cylinder Bore Diameter: 3.3858-3.3870" (85.999-86.03 MM)
Piston & Pin Info
Skirt Oil Clearance: .0028-.0035" (.071-.089 MM)
Pin Diameter: .8660-.8665" (21.996-22.009 MM)
Pin Type: Float
Ring Gap: Top .013-.022" 2nd .018-.026", Oil .008-.024"
Housing Bore Info
Torque: 43 FT/LBS
Crankshaft Info
Stroke: 3.386" (86.004 MM)
Cylinder Bore: 3.3858-3.3870" (85.999-86.03 MM)
Rod Journal
Journal Diameter: 1.8892-1.8898" (47.986-48.001 MM)
Oil Clearance:.0009-.0022" (.023-.056 MM)
Main Journal:
Position 1: 2.1648-2.1654" (54.986-55.001 MM)
Oil Clearance: .0005-.0024" (54.986-55.001 MM)
Crankshaft End Play:.0008-.0087" (.02-.221 MM)
Connecting Rods Info
Big End Housing Bore: 2.0079-2.0087" (51.001-51.021 MM)
Big End Side Clearance: .0063-.0123" (.16-.312 MM) Big End Width 1.055"
Torque: 18 FT/LBS, + 90 degrees
Small End Finished ID: .8663-.8668" (22.004-22.017 MM)
Center to Center Distance: 5.4280" (22.004-22.017 MM)
Twist/Bend: .002/.006 @ 3.94
Camshaft Info
Cam End Play: .005-.009" (.127-.229 MM)
Cam Journal Specs: 1.0614-1.0620" (26.96-26.975 MM)
Cam Journal Oil Clearance: .0010-.0024" (.025-.061 MM)
This post has been edited by Mstoochn: Dec 30, 2009 - 12:32 AM
post Dec 30, 2009 - 1:51 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
In regards of the piston manufacturers compression ratio spec is off of different head gaskets.
for example, CP list their pistons at 8.5:1 where as JE lists them at 9.0:1.
But in reality its what head gasket you use at the end. The manufacturer is listing their compression ratio off of the head gasket they are using for measurement.
94 Celica gt white (sold)
post Dec 30, 2009 - 3:26 AM
Mstoochn
Joined Apr 27, '09
that # is still modified based on what headgasket you use, for instance HKS offeres a 3s 8.8 and 8.5 gasket, where as you can also use the 5s 9.0 or 9.5 gasket.
but prefabricated pistons for the 3s-gte from CP, Eagle, Pauter or other manufacters for the sake of clarity are going to measure based off of a stock headgasket.
custom pistons will be a different story depending what specs are go by
This post has been edited by Mstoochn: Dec 30, 2009 - 3:28 AM
post Dec 30, 2009 - 9:00 AM
nemesis
Joined Jan 14, '06
Would I be better off going with an 8.5:1 or 9.1:1 since I can't find the factory spec of 8.8:1?
post Dec 30, 2009 - 9:03 AM
nemesis
Joined Jan 14, '06
Meant 8.5:1 or 9.0:1 (sorry).
QUOTE (nemesis @ Dec 30, 2009 - 10:00 AM) *
post Dec 30, 2009 - 11:46 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
according to http://www.celica-gt4.com/tech-data
st205 (gen3 3sgte): 8.5:1
st185 (gen2 3sgte): 8.8:1
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post Dec 30, 2009 - 12:55 PM
Mstoochn
Joined Apr 27, '09
QUOTE (BriinumsBo @ Dec 30, 2009 - 11:46 AM) *
... 8.5, see my PM nemesis
Lo-Fi Version Time is now: August 23rd, 2026 - 3:19 PM
