> engine/fuel problems for non 6g, 2000 ford contour..
post Jan 2, 2010 - 4:30 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
alright here we go, the contour drives great, up to about 55. it does ok for a bit but once it gets to 65 for even a mile or less it just shuts down. if i touch the gas is dies. is this a bad(old and tired) fuel pump and/or filter? or the injectors? please help guys, thanks in advance.
Replies (1 - 2)
post Jan 2, 2010 - 4:35 PM
HaysoosKreesto
Joined Nov 4, '09
From Sacramento, California
http://www.carcomplaints.com/Ford/Contour/..._car_dies.shtml
This might or might not help. But the most useful part (that I could see) is that "That is when the mechanic did some research on recalls and such. Found that there is some sort of sensor or chip on or near the pump that keeps frying. Once this was replaced I have not had a problem with that issue. It has been over 3 years now."
But there is just a whole host of odd-ball complaints on this lol.
post Jan 2, 2010 - 5:54 PM
Hanyo
Joined Aug 16, '03
From Bay area
"that sensor" they talk about is the emergency fuel cut off sensor. It detect when a car has flipped upside down and cuts off the fuel pump. Those things do go bad and randomly cut off the power to the fuel pump.
To test that sensor, the cheapest way is to run power directly from the battery to the fuel pump. If your car drives fine change the sensor.
However if you still have problems, change the fuel filter and see if you can get your fuel system pressure tested and match according to the manufacture specification. If your fuel pressure is not correct it would be a bad fuel pump. Or a bad fuel strainer that gets clogged up and starves your fuel pump.
Lo-Fi Version Time is now: August 11th, 2026 - 3:36 PM
