Jan 2, 2010 - 6:03 PM
Well I finally got around to building turbo pipes. that all went fairly smooth. It was tough trying to figure out the routing, i didnt want to go over the head like most FMIC setups. So i clocked the turbo down and went the way i did.
So on the dyno, I ran into the same issue that the Scion is running into with the AEM FIC. We were hitting a block at 4000 RPM,s the car would just shut off. After a quick run to Radio Shack, picked up some 1K ohm resistors and fixed the problem. ill post pics of that later if wanted. The AEM FIC is a good unit and it works well. i need to go back and finish some fine tuning. im getting a lean condition at throttle tip in. So with that said and done, i made 176HP and 230lbs TQ at 6.5psi. im on the stock exhaust after the ebay downpipe so i really need to open that up. i plan on upping the boost to about 10psi. ![]() ![]() ![]() ![]() ![]()
This post has been edited by Smaay: Jan 5, 2010 - 11:38 AM -------------------- 2001 Celica GT-S Turbo
Smaay Finishes turbo system, got on a Dyno Jan 2, 2010 - 6:03 PM
95st-celica pics not working homie Jan 2, 2010 - 6:04 PM
Smaay should be working now Jan 2, 2010 - 6:10 PM
manphibian no Jan 2, 2010 - 6:21 PM
Smaay wierd i can see them. try looking here
http://www... Jan 2, 2010 - 6:24 PM
presure2 lookin good man!
thats a greddy type s BOV? st... Jan 2, 2010 - 7:34 PM
spitfiremk16 mind if i ask what the resisitor is for? i plan on... Jan 2, 2010 - 8:04 PM
Smaay no its a micky mouse BOV. i get the pipe kits from... Jan 2, 2010 - 9:03 PM
spitfiremk16 checked out the pics and i like the piping, that k... Jan 2, 2010 - 9:37 PM
Smaay i did, the above link where i got the pipes. Jan 3, 2010 - 12:23 AM
Smaay added the dyno to first post Jan 5, 2010 - 11:39 AM
GriffGirl That's a really clean, nice looking build... Jan 5, 2010 - 3:37 PM
Smaay QUOTE (GriffGirl @ Jan 5, 2010 - 12... Jan 6, 2010 - 12:42 AM
jeffrosie Looks like your water pipes for turbo cooling are ... Jan 5, 2010 - 4:25 PM
whatthe Oh man looking sick. I want to join this 5sfte clu... Jan 6, 2010 - 11:20 AM
D_Dawg Will you be relocating the oil filter? Jan 6, 2010 - 10:41 PM
Smaay i dont have a plan to relocate it. Jan 8, 2010 - 8:45 PM
bmj67 did you dl your new tune from the fic Jan 8, 2010 - 9:27 PM
Smaay not yet, i guess ican do that real quick for every... Jan 9, 2010 - 12:27 PM
Smaay Here is my FIC MAP
Analog A is the OEM MA... Jan 9, 2010 - 12:42 PM
FunkySR is it just me or is your fuel map a bit jumpy. I t... Jan 9, 2010 - 5:08 PM
Smaay try pulling some timing Jan 10, 2010 - 12:11 PM
FunkySR I read somewhere that I did not need to adjust tim... Jan 10, 2010 - 12:29 PM
Smaay on an NA engine and you dont need to pull timing w... Jan 11, 2010 - 9:46 AM
FunkySR ok, by the by. I will sort the timing out....but t... Jan 11, 2010 - 1:23 PM
Smaay do it the same way i guess. read the link i posted... Jan 11, 2010 - 3:08 PM
Smaay Talking to Jim the other day enlightened me. i gue... Jan 14, 2010 - 11:21 AM
Mstoochn QUOTE (Smaay @ Jan 14, 2010 - 11:21 ... Jan 14, 2010 - 1:40 PM
Smaay i was thinking about that. what head 3S-GE or 3S-G... Jan 14, 2010 - 4:22 PM
bccentaur3 Looks like he means 3sge head. Thats what I'm ... Jan 14, 2010 - 4:37 PM
Mstoochn QUOTE (bccentaur3 @ Jan 14, 2010 - 5... Jan 14, 2010 - 5:02 PM
Smaay well i better start doing research. does the 5S ma... Jan 14, 2010 - 5:42 PM
Mstoochn QUOTE (Smaay @ Jan 14, 2010 - 6:42 P... Jan 14, 2010 - 5:59 PM
Smaay well after reading through this, i think im gonna ... Jan 15, 2010 - 9:51 AM
bccentaur3 Thats a gen 1 3sge head. Thats what I'm using ... Jan 15, 2010 - 1:30 PM
Smaay uummm yeah! im definatly not going to mess wit... Jan 15, 2010 - 2:22 PM
GriffGirl I hate that you have every car that I really, trul... Jan 15, 2010 - 6:12 PM
Smaay you have to get down here first Jan 17, 2010 - 12:21 PM
GriffGirl I might be in vegas at the end of the month, don... Jan 17, 2010 - 7:59 PM
Smaay Vegas baby! i dont know if i posted it on here... Jan 20, 2010 - 3:24 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 5:59 AM |
