Jan 5, 2010 - 2:37 AM
Enthusiast ![]() ![]() ![]() Joined Dec 20, '07 From Valkeakoski, Finland Currently Offline Reputation: 0 (0%) |
Okay, so my front rightside wheel bearing has started to make noise, and is in need of change.
I hope the noise is from the braring, not the driveshaft.. but the thing is this, at local dealership the price was 206€, so its 300$ for a bearing. un-original part, is only 60€ = 86$.. but they couldn´t tell for sure is it a perfect fit, so does anyone have a clue of the bearing size? Could it be 74 mm outer diameter, 38mm inner diameter and 36mm wide? thanks, Penkka. -------------------- |
Penkka Help needed with wheel bearing! Jan 5, 2010 - 2:37 AM
808celica are gt4 and usdm gt's alike?? you might wanna ... Jan 5, 2010 - 2:53 AM
azian_advanced wheel bearings for all celicas are the same... whe... Jan 5, 2010 - 8:00 AM
Penkka QUOTE (azian_advanced @ Jan 5, 2010 - 8... Jan 5, 2010 - 10:53 AM
zoik theres a difference beetween wheelbearings, depend... Jan 5, 2010 - 2:12 PM
garin QUOTE (Penkka @ Jan 5, 2010 - 2:37 A... Jan 5, 2010 - 5:48 PM
Penkka Zoik: yeah there are different bearings on abs/non... Jan 5, 2010 - 10:33 PM
garin QUOTE (Penkka @ Jan 5, 2010 - 10:33 ... Jan 5, 2010 - 10:39 PM
Penkka yeah, its not that big of a deal? Jan 5, 2010 - 10:43 PM
garin well just make sure you do it right... have you ev... Jan 5, 2010 - 11:12 PM
Penkka done much bigger things, the only problem about th... Jan 6, 2010 - 8:20 AM
garin yea, i'm just saying make sure you do it right... Jan 6, 2010 - 9:41 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 9:52 AM |
