Jan 6, 2010 - 5:00 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
i have a 94 st.. and it doesnt start when is cold... i have to keep trying till it warm otherwise it turns off....one it is warm i can turn it off and on fast... what could be the problem?
Jan 6, 2010 - 5:31 PM
![]() Enthusiast Joined Dec 23, '09 From Nashville, TN Currently Offline Reputation: 0 (0%) |
did you try depressing the accelerator a little to keep it running until it warms up?
I, and several others, have this problem. Still awaiting a solution. http://www.6gc.net/forums/index.php?showtopic=71407 |
Jan 6, 2010 - 6:19 PM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
replace coil, wouldn't be the first 100 times this has happened.
Jan 7, 2010 - 2:57 AM
Enthusiast ![]() ![]() Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
Check your coolent temp sensor my car would not start until I wiggled the wire just the right way, then I found it was corroded inside(it looked fine) and had to replace it. It is the second one to the right of where the top hose connects to the engine. Since I replaced (15.00 autozone) it starts cold perfectly every time.
| Lo-Fi Version | Time is now: July 29th, 2026 - 1:33 AM |
