> what parts are withe the electrical system, check last post for update
post Jan 6, 2010 - 7:58 PM
mk7celica
Joined Feb 2, '09
From new orleans La.
car dies its somthing electrical
This post has been edited by mk7celica: Feb 1, 2010 - 11:20 PM
- mk7celica   what parts are withe the electrical system   Jan 6, 2010 - 7:58 PM
- - southwest2118   well defiantly if there's something causing ex...   Jan 6, 2010 - 8:17 PM
- - mk7celica   Sounds like a plan thanks   Jan 6, 2010 - 8:49 PM
- - mk7celica   Does a 5sfe alternator bolt up to a 3sgte an brack...   Jan 8, 2010 - 7:39 PM
- - lagos   The 5sfe alternator bolts right up however it uses...   Jan 8, 2010 - 8:30 PM
- - mk7celica   Quick Question, I am about to run a new wire fr...   Jan 16, 2010 - 3:13 AM
- - lagos   you keep all the factory stuff in place. All you a...   Jan 16, 2010 - 10:55 AM
- - 99GT   Same thing happend. Replace alternator. Doc sen...   Jan 16, 2010 - 12:15 PM
- - GriffGirl   It sounds like you melted your ground wire, you ne...   Jan 16, 2010 - 3:02 PM
- - mk7celica   So I ran a new wire and put the old alternator in ...   Jan 22, 2010 - 7:25 PM
- - mk7celica   wideband at 17 help   Jan 23, 2010 - 8:19 PM
- - GriffGirl   Check ALL of your ground wires, there's more t...   Jan 23, 2010 - 9:52 PM
- - lagos   sounds like you still have an alternator problem. ...   Jan 24, 2010 - 10:56 AM
- - mk7celica   So I tested the alternator when it was first start...   Jan 27, 2010 - 7:01 PM
- - Mstoochn   i hope your Wideband is reading wrong... 13 is lea...   Jan 27, 2010 - 7:16 PM
- - mk7celica   Ordered new ayternator should be here tommorow eve...   Jan 31, 2010 - 6:27 PM
- - lagos   QUOTE (mk7celica @ Jan 31, 2010 - 6...   Feb 1, 2010 - 1:44 AM
- - mk7celica   New alternator went in an still did the same. I fi...   Feb 1, 2010 - 7:41 PM
- - mk7celica   Ok 2 questions can someone give me a list of all ...   Feb 1, 2010 - 11:22 PM
- - mk7celica   Its fixed its fixed I am so happy.   Feb 2, 2010 - 8:29 PM
- - lagos   QUOTE (mk7celica @ Feb 2, 2010 - 8:2...   Feb 2, 2010 - 8:54 PM
- - mk7celica   Well after redoing every ground in the bay the car...   Feb 2, 2010 - 10:48 PM
Lo-Fi Version Time is now: July 29th, 2026 - 5:19 AM
