> 94 ST main fuse?, is there one? and where is it?
post Jan 9, 2010 - 3:38 PM
mgnt232
Joined Mar 16, '09
my car has no power, but the battery/starter/alt/grounds/connections are all good. And my friend said this happened to his car, it was a little older and there is a "main fuse"? idk if my 94ST has this? thanks people!
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Jan 9, 2010 - 8:54 PM
mgnt232
Joined Mar 16, '09
BUMP
QUOTE (mgnt232 @ Jan 9, 2010 - 3:38 PM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Jan 9, 2010 - 9:26 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Are you getting no power whatsoever or is it just the engine that doesn't run? If that's the case, check the AM2 fuse in the engine compartment fuse box on the driver side. Rats chewed my injector wires so one was touching the intake manifold and was causing my car to blow the fuse randomly and keep blowing the new ones. The car wouldn't run or even start. No clicks. NOTHING. It had power but wouldn't run.
If there is no power like if the car doesn't have a battery, it's the main fuse that's located on that same fuse box I mentioned. It's a big square one. One of the big ones.
This post has been edited by OOBE: Jan 9, 2010 - 9:28 PM
post Jan 9, 2010 - 9:36 PM
mgnt232
Joined Mar 16, '09
I am getting no power, as if the battery was dead but, the battery is fine. How do i check/know if the big square fuses are bad? I know just looking at the smaller ones, you can see the internal wire (good or broken) but im not sure how to check the others, such as the "main fuse" cause i think this may be whats wrong.
any idea what fuse it is?
QUOTE (OOBE @ Jan 9, 2010 - 9:26 PM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Jan 9, 2010 - 9:53 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
There is sticker inside the lip od the fuse box and it tells you which fuse is which. You can check the fuse with a tester. They have a clear cap so you should be able to see if it's blown or not. If you can't see it, then use a tester.
post Jan 9, 2010 - 10:31 PM
mgnt232
Joined Mar 16, '09
Alright im getting it towed back to my house 2m and ill check them all, what is a fuse tester? can i test them with a DVOM? liek the resistance? idk how that works with the bigger fuses
QUOTE (OOBE @ Jan 9, 2010 - 9:53 PM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Jan 10, 2010 - 5:20 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
No, man. Just a regular tester. They sell cheapy ones at Walmart or Advanced Auto/Pep Boys. You can test circuits with them. A fuse is something simple. Current flows from one side to the other. You need to test that. If you don't get current on the other side, then it's blown. That's how I test a fuse that doesn't have a window to see if it's blown or not.
Lo-Fi Version Time is now: May 28th, 2026 - 4:23 AM
