> Clutch problem... Again
post Jan 10, 2010 - 3:00 AM
my96celica
Joined Jul 15, '07
From High ridge MO
Okay so my clutch is having the same problem as before. I replaced the slave and I bleeded the line and it worked for about 10 miles then again the same thing. did I not get all the air out ot what?
Replies (1 - 13)
post Jan 10, 2010 - 4:02 AM
probably the master.
post Jan 10, 2010 - 9:45 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
master... or disc has bad springs
Breaking Axles...
post Jan 10, 2010 - 2:20 PM
my96celica
Joined Jul 15, '07
From High ridge MO
There is a little air in the line. I must of bleeded it like 30 times and still air in the line. I dont think its the master.
post Jan 10, 2010 - 4:14 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You check to see if you have a leak somewhere?
post Jan 10, 2010 - 4:26 PM
my96celica
Joined Jul 15, '07
From High ridge MO
Yes. no leaks
post Jan 10, 2010 - 4:31 PM
my96celica
Joined Jul 15, '07
From High ridge MO
I am at a freinds house and his dad tells me i should only pump the clutch one time and hold it then bleed it. He says that me pumping the clutch might be moving air from one side of the line to the other. Is this true? Seems to me that one pump will not build any pressure.
post Jan 10, 2010 - 7:38 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
you wanna open the bleeder when you have the clutch to the floor, than have someone tighten it when its still to the floor and repeat that a few times.
2nd Gen 3s-gte.... It lives!
97celiman
post Jan 10, 2010 - 7:40 PM
dabazied
Joined Jun 10, '07
From Riverside, CA
^^^^ agreed, and if that doesn't work, it is most likely, guaranteed your master cylinder, had the same issue a couple yrs back.
She's Alive...... Again!!!
Sweet Jesus.
You rang?
Sorry, wrong number. :laugh:
post Jan 11, 2010 - 2:56 AM
my96celica
Joined Jul 15, '07
From High ridge MO
The master cylinder I think is working. The fluid is going through it. The main problem is I bleed it and there will be pressure then I get no pressure if I keep bleeding. I have to keep bleeding cause I know all the air is not out of the line. I have not tried to gravity bleed it yet. Do i have to push the clutch in then gravity bleed. I have never had to do it before.
post Jan 11, 2010 - 3:22 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
i told you to gravity bleed it, that doesnt need any pumping. That is the sure way to get all air out.
post Jan 11, 2010 - 3:54 AM
my96celica
Joined Jul 15, '07
From High ridge MO
post Jan 11, 2010 - 5:21 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
what's the feeling you have on the clutch pedal? does it feel normal then slowly soften?
post Jan 11, 2010 - 2:06 PM
my96celica
Joined Jul 15, '07
From High ridge MO
So I tried to gravity bleed it and its been about half an hour and the fluid level has not droped and there is no fluid coming out of the bleeder screw. Does this mean its my master?
Lo-Fi Version Time is now: August 27th, 2026 - 10:39 AM
