> Best Oil, Whats the best oil
post Jan 10, 2010 - 9:43 PM
zfjohnson07
Joined Apr 11, '09
I'm sure theres a thread somewhere, but i just figured i might as well open a new thread since theres a lot of new people on this website. So back to the question, What's the best oil to run, or is the synthetic oil better?
post Jan 10, 2010 - 9:44 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
Mobile 1 - 1000 5w30 full snythetic is proven the BEST lubtrication in our engines particulary
post Jan 10, 2010 - 9:46 PM
zfjohnson07
Joined Apr 11, '09
if you do synthetic do you have to change anything before changing oils
post Jan 10, 2010 - 9:49 PM
Mstoochn
Joined Apr 27, '09
QUOTE (zfjohnson07 @ Jan 10, 2010 - 10:46 PM) *
no, unless you go to a shop they will try and sell you an oil "flush" which is a horrible thing to do..
post Jan 10, 2010 - 9:58 PM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
Be weary of full synthetic, it works well, but it's known to mess up the seals. I put it in my car, a month later my oil crank case was empty. Found this out when I went around a hard turn and actually heard my engine grind, and my oil light flashed on. Stopped at the store, and found my oil empty and had to put oil in it on the spot.
Now don't get me wrong, I believe that full synthetic works, but not on super old engines. And honestly, my car only has 80,000 miles. 7A-FE.
post Jan 10, 2010 - 10:15 PM
zfjohnson07
Joined Apr 11, '09
ive heard that when you change your oil that you have to change your seals but do you feel good power or what>
post Jan 10, 2010 - 10:52 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
i use redline on my car. the celica gets mobil1 full synth.
post Jan 10, 2010 - 10:58 PM
zfjohnson07
Joined Apr 11, '09
you use redline on your car? whats that im illiterate
post Jan 10, 2010 - 11:25 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Castrol Magnatec (Which is Semi-Synthetic) for 3S-GE and 3S-GTE,
wont be too bad for the *S-FE either, But not critical, It's no high performance engine.
There are certain conditions to be weary about when choosing a fully synthetic oil, search the net. The same things apply to oil flush aswell. -- For example, an older engine where organic oil residue is creating a seal against a worn seal, a fully synthetic wont have these same properties.
I highly recommend oil catch tanks too, Install them and you'll see how much you're keeping out of the intake system after a few drives.
Oh yeah, Redline oils are said to be the best for our cars, Especially our gearboxes and diffs.
Mike W
269awhp / 273ft-lbs
post Jan 11, 2010 - 1:33 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
valvoline full syn is what i use, its pricey but well worth it, i currently have it for the 300k miles warranty by valvoline if you registar it before you hit 75k miles
post Jan 11, 2010 - 8:40 AM
CastrolCelica
Joined Sep 27, '09
From Columbus, Ohio
Mobil 1.
Yea, I'm joking.
post Jan 11, 2010 - 11:09 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Purple Royal has been proven to be the #1 oil that you can use. But due to the price differences I stick with what ever is cheapest in synthetic at stores. There's a PDF file somewhere that proved this with cylinder tests.
post Jan 11, 2010 - 11:16 AM
Artega
Joined Apr 2, '07
From Calgary, Alberta
I'm using AMS oil right now in my 3S-GTE
post Jan 11, 2010 - 11:31 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (soulshadow @ Jan 11, 2010 - 11:09 AM) *
very true, but even after seeing that pdf file some members said royal purple was cheap and wasnt that effective. So who do you believe the actual tests or people's testimonials?
Once you go synthetic there is no turning back right? I mean once you start to use synthetic then you cant go back to semi-synthetic?
I personally wouldnt waste my money on synthetic for the weak 7afe, and 5sfe economy engines. Unless of course your 7afe or 5sfe is turbo charged. Then thats a different story.
post Jan 11, 2010 - 12:40 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I use synthetic on my weak n/a 7AFE, I've always used synthetic in all my cars. Depending on the budget, sometimes I switch between synthetic blend and full synthetic. I stay w/full synthetic if I can though. Right now I've got Mobil 1 Synthetic in my car, 10w-30. Very happy with it, motor pulls strong and feels great. Low end torque is about all my motor has to offer, so I do what I can to maximize its offerings.
Ultimately, whatever oil you use, NOTHING substitutes for regular fluid changes and maintenance.
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE (BonzaiCelica @ Jan 11, 2010 - 10:31 AM) *
On the 5sfe or 7afe there is no need to waste the money on Mobil 1 synthetic or anything like that. The 3sgte, maybe, new performance car, yes. On these older economy engines all we need is regular old oil.
I personally use the Valvoline high-mileage synthetic blend in both my cars. It's inexpensive, and works really well.
1999 Celica GT
post Jan 11, 2010 - 12:46 PM
BonzaiCelica
Joined Apr 24, '08
ya its kind of a waste to use synthetic blend on 7afe and 5sfe. I mean only if you're going to race your 7afe or 5sfe(which isnt really a good idea). I use valvoline, castrol, or any high mileage over 75,000 miles synthetic blend.
post Jan 12, 2010 - 1:55 AM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
gtx!
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post Jan 12, 2010 - 3:44 AM
Hanyo
Joined Aug 16, '03
From Bay area
mobile 1.
I heard the castrol edge was good stuff, but i don't see it worth the price difference.
post Jan 14, 2010 - 2:39 AM
DKGT4
Joined Sep 25, '09
From Edmonton
The use of oil also depends on the conditions of your environment as well. If you have reg oil and live in cold areas like where in live in Canada were we had a record low of -58 degrees celcius, I definitely recommend using a mix of 50/50 or 75/25 synthetic to regular oil. You can even use full synthetic but make sure you get new seals. You might find leakage.
Right now I use full synthetic Royal Purple 5w30 and I have only used that for my oil changes.
Peace!!
Lo-Fi Version Time is now: July 29th, 2026 - 3:55 PM
