> Fixing PS pump - Any tips appreciated.
post Jan 11, 2010 - 4:02 PM
rave2n
Joined May 29, '09
From Gainesville, FL
As topic states, my PS pump has gone bad, and needs to be replaced. I have acquired another from a member here for a fraction of the cost of a new one (Thank you muches sir) Instead of purchasing a new one, being I plan to swap within a couple or so months. I just can't take the belt squeel anymore, and the spill of fluids everytime I add more fluid, and no its not any of lines. Thats all been checked, its the res that is the issue, but i figured since i'm going to change that out, just do the whole thing.
So my question is, does anyone have any tips to get this done easier then what is stated in the hayes manual. It states to remove some metal shield, and the right front axle (Done all this before, so I know that process...it sucks) . Of course then remove all tension from belts and proceed to remove the pump from under the vehicle etc. Thats all well and dandy, just doesn't seem like the best way to accomplish the task. Which is why I ask you pros of the 6th gen celicas. Thank you in advance.
Lo-Fi Version Time is now: August 25th, 2026 - 2:08 PM
