Jan 15, 2010 - 1:46 PM
Enthusiast ![]() Joined Aug 23, '09 From Ohio Currently Offline Reputation: 0 (0%) |
If anyone has a set of fog lights , send pictures if you would. I would like to buy a set because my car never came with them and I'm going with the full H.I.D. look with lights. I will need everything needed from the units, to the wiring and then a switch of some sort to turn them on inside of the car. I don't know if I either eventually will turn them on from the regular lights switch or install a switch where underneath the steering wheel there is rectangle on both right and left sides. I figure that is where a switch goes and you cut that plastic out. If you can explain to me how to set up the fog lights, I also will appreciate that as well.
Thank You Seth(CelicaST96) |
| Lo-Fi Version | Time is now: September 1st, 2026 - 1:00 PM |
