> 5SFE, Distributor or coil packs???
post Jan 17, 2010 - 5:21 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
The 99 3SFE in UK has 2 coil packs each feeding 2 cylinders, so 1 gets a spark on compression and 3 gets it on exhaust. Same with 2 and 4.
Is the 5SFE the same as this or does it come with a distributor?
Reason I'm asking is because I want to drop a 3SGE in my car in place of the 3SFE, but use all the FE electrics and have it all sdjusted usinga fuel & ignition controller as these are the 2 values that will have to be changed.
Apexi SAFC II will be used.
Will it work?
post Jan 17, 2010 - 5:38 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
the 5s-fe uses a dist, just like the 3sfe
This post has been edited by Mstoochn: Jan 17, 2010 - 5:57 PM
post Jan 17, 2010 - 5:57 PM
jeffrosie
Joined Sep 11, '08
post Jan 17, 2010 - 5:58 PM
Mstoochn
Joined Apr 27, '09
QUOTE (jeffrosie @ Jan 17, 2010 - 5:57 PM) *
no.
jeffrosie
Joined Sep 11, '08
Will try and get a pic of the engine.
post Jan 17, 2010 - 6:03 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
5s distrib has a primary and secondary coil inside.
post Jan 17, 2010 - 7:04 PM
jeffrosie
Joined Sep 11, '08
I think it will work.
In UK the 3SFE does not have a distributor. It uses a crank pickup and coil packs instead. The distributor hole is blanked.
So fitting a GE cylinder head in place of the FE cylinder head will only create the need for the engine to take in more air which will need more fuel - just the same as forcefeeding the FE engine. Correcting the ignition timing will just make it more efficient.
post Jan 19, 2010 - 7:21 AM
trdproven
Joined Aug 2, '05
From Guam
you just have to convert it to coil pack instead of distributor coil.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 21, 2010 - 2:40 AM
Joe_1985
Joined May 3, '09
From jacksonville/flemming island florida
i know the later camry 5sfe's had coil packs
94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine
85 celica gt-s project
Lo-Fi Version Time is now: August 25th, 2026 - 6:53 PM
