> 3sgte trans on 5sfe
post Jan 18, 2010 - 4:20 PM
yaj204
Joined Nov 29, '07
From california, marysville
my transmission is making some noise and one of my buddy has a spare tranny off his 3sgte lying around, was wondering if its gonna work with the 3sgte tranny on my 5sfe motor.
post Jan 18, 2010 - 4:31 PM
mk7celica
Joined Feb 2, '09
From new orleans La.
A 3sgte tranny is awd and 5sfe is few won't work
post Jan 18, 2010 - 4:43 PM
yaj204
Joined Nov 29, '07
QUOTE (mk7celica @ Jan 18, 2010 - 5:31 PM) *
hahaha no.. its off a mr2
post Jan 18, 2010 - 5:09 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (mk7celica @ Jan 18, 2010 - 1:31 PM) *
yeah they come on MR2s also. but the MR2 tranny has the selector shaft on the wrong side. the AWD tranny can be converted to FWD
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 18, 2010 - 5:29 PM
QUOTE (Smaay @ Jan 18, 2010 - 5:09 PM) *
just FYI, the MR2 tranny can also be converted to FWD use quite easily, just a couple bolts on top of the tranny to pull out the MR2 tranny shifter levers, and 4 bolts on the back side to install the camry or solara main lever.
then there are 2 bolt holes that you drill and tap for the other lever.
its actually very simple once you have the tranny and parts to convert it in front of you.
IIRC there are pics of it in jims build thread from when i did his mr2 LSD tranny.
post Jan 18, 2010 - 5:50 PM
yaj204
Joined Nov 29, '07
QUOTE (presure2 @ Jan 18, 2010 - 6:29 PM) *
u mind showing me the pictures or the thread?
post Jan 21, 2010 - 9:13 PM
Scrappy_celi
Joined Jan 19, '10
From Tacoma Wa
Hey, I'm a noob. I'm trying to research all I can on my new Celica. I've seen many people say you can use an MR2 tranny or an AWD tranny on a FWD Celica. I haven't been able to find any posts detailing what needs to be done for either of these options, and I figured this was that post to ask on!
post Jan 21, 2010 - 10:07 PM
Culpable04
Joined Apr 17, '06
From New Jersey
keep in mind that stock 5sfe bolted to a e153 ( MR2 turbo transmission ) will make you hate your car, it'll feel / be slow as it can get, because the transmission is designed for different power levels than a non turbo 5sfe can deliver. so you either turbo the engine along with this transmission swap, or look for a different transmission from a camry. solara, mr2 or celica, make sure it comes from a 4 cylinder and not from a v6 or turbo car.
post Jan 30, 2010 - 8:31 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (Smaay @ Jan 18, 2010 - 3:09 PM) *
Details?
This post has been edited by KAOS: Jan 30, 2010 - 8:31 AM
post Jan 30, 2010 - 11:07 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Theres a write-up on celicatech for this. But basically you'll need a differential from an mr2 and have to remove all the internals and put it all back together.
94 Celica gt white (sold)
Lo-Fi Version Time is now: August 27th, 2026 - 12:41 AM
