Jan 18, 2010 - 10:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I've got an ST and as you know, the rear brakes are drums. I want to swap them out for discs and I'm going to go junkyard hopping soon and I know the GTs have discs, so what would I have to pull from the GT to make the brakes work on my ST?
This post has been edited by HectortheRican: Aug 27, 2010 - 3:37 PM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Jan 18, 2010 - 10:30 PM
Enthusiast ![]() ![]() Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) |
There are a TON of threads about this. I made one myself. But here is a very well written write up. I know that GriffGirl has also done it recently.
http://6gc.net/howto/convert_rear_drums_to_discs Good luck! (Don't forget the e-brake cable.) |
Jan 19, 2010 - 12:31 AM
The how-to in the above post is EXACTLY what I used to do my swap
Jan 19, 2010 - 12:35 AM
There are a TON of threads about this. I made one myself. But here is a very well written write up. I know that GriffGirl has also done it recently. http://6gc.net/howto/convert_rear_drums_to_discs Good luck! (Don't forget the e-brake cable.) Alright this will be a big help, but how do I pull them off of a GT if I find what I'm looking for in a junkyard? And how will I know if they're ABS? I'm pretty new to the whole mechanics stuff but I'm hoping to learn -------------------- taking too long to mod since '09
Jan 19, 2010 - 12:52 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
look under the hood of the car,behind the passenger side headlights between the wheel wells there will be a box with metal lines coming out of it,if there is no box..there is no ABS
-------------------- BANNED. for life, you moron.
Jan 21, 2010 - 12:29 PM
Enthusiast ![]() ![]() Joined Nov 6, '07 From seattle Currently Offline Reputation: 4 (100%) |
I just finished my disc brake swap last weekend, but i have a question. How many lb should the spindle be torqued back onto the knuckle? The tutorial only states tighten by hand, but i don't want to risk having any bolts loosening on me while driving.
This post has been edited by bizzerk: Jan 21, 2010 - 12:30 PM -------------------- ![]() |
Feb 2, 2010 - 5:17 PM
Enthusiast ![]() Joined Jul 8, '09 From DuBois PA Currently Offline Reputation: 8 (100%) |
so ABS brakes dont work in the conversation?
Aug 12, 2010 - 1:54 AM
Enthusiast ![]() ![]() Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) |
so ABS brakes dont work in the conversion? I want to confirm this. I found a GT with ABS at the junkyard and want to do the swap. Anyone actually tried and succeeded/failed at this? And if so, what is the reason they dont fit? It looked to me like they were exactly the same, except a pair of wires coming from a grommet in the top of the wheel well to control the ABS unit. This post has been edited by zonz540: Aug 12, 2010 - 1:55 AM |
Aug 12, 2010 - 3:29 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
yes it does work i has been done before by a member he said he had no problem with it
Aug 12, 2010 - 12:08 PM
Good to hear. Thanks Johnnyny
Aug 12, 2010 - 1:11 PM
yep no probelm i got my disc brake assembly forn a GT with abs i was pretty upset thought i wasnt going to be able but i searched and searched and found dat it had been done before succesfully and there was no problem! i was like yaii!! lol
Aug 12, 2010 - 2:27 PM
Oh that's great! This doubles my opportunity to find some haha
Aug 20, 2010 - 1:48 AM
Got the disc brakes on. The ABS has no bearing on whether they will work or not. You can just use the ST hub and bolt the brake assembly behind it. The brakes are the exact same.
Although, i ended up using the drum pads that came on them because the pads i got at autozone were too thick? The physical part size was the same, but the rotors wouldnt fit over the thicker pads... We may want to update the how-to. |
Aug 27, 2010 - 3:43 PM
I'm at Just Brakes to check the drums if they need replacing. Just for kicks, I asked them if they'd do the rear disc conversion for me since I'm at college living in dorms and I have nowhere to take apart my car. They said that I need more than just the internal drums, rotor, caliper, pad, and e brake lines. They said I'd need to replace the ABS pump and master cylinder, etc. in order for the right pressure to be distributed throughout the brakes. It'd be great if someone could prove/disprove this because I've looked through a few drum to disc conversions and not once did I see anything about ABS pumps or master cylinders. Thanks guys.
| Lo-Fi Version | Time is now: August 29th, 2026 - 12:50 PM |
