Jan 21, 2010 - 11:15 PM
Enthusiast ![]() ![]() Joined Feb 24, '09 From Scranton, PA Currently Offline Reputation: 13 (100%) |
Ok, I've had two Celicas in my car owning career. A 94 st and a 94 gt both hatchbacks (obviously) and on neither one does the rear window washer thing work. Was that a problem among all 94s or was i just lucky enough to get 2 broken ones??? And does anyone know how to fix it??
Jan 22, 2010 - 3:36 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
U may have to find the blockage or leak, trace it back from the washer bottle and the pump (under the F/Right wheel arch covers), the line to the rear runs along the right side of the car, I think its the tube thats under the right door bottom trim and carpet, unless thats fuel I'll be damned.
-------------------- Mike W
Jan 22, 2010 - 3:47 AM
U may have to find the blockage or leak, trace it back from the washer bottle and the pump (under the F/Right wheel arch covers), the line to the rear runs along the right side of the car, I think its the tube thats under the right door bottom trim and carpet, unless thats fuel I'll be damned. Yes, the rear washer hose runs under the door sill along the right side. You msy have to look under the edge of the carpet, but it's there. -------------------- ![]() |
Jan 22, 2010 - 8:50 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
of the four celicas i owned only one worked when i bought it. but then, i hadn't even tried the 4th lol. its sitting in my driveway patiently awaiting her V6
Jan 22, 2010 - 12:43 PM
Anyone ever notice that when you're holding the rear window wiper stalk to the furthest twist position (to activate rear window wash fluid) that sometimes your front wipers randomly activate?
Jan 22, 2010 - 2:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
^ Nope, that must be only you. I can confirm that the fluid line does indeed run under the door sill. And FWIW, mine has always worked...so I would say it's a block in the line like someone said, or it might just be the pump not working? Try listening to what happens when you twist the stalk because on mine, I hear the pump...pumping. If you don't hear anything, the pump's probably bust, and if you do, there's most likely a block, or leak.
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Jan 22, 2010 - 5:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
iirc there are 2 pumps or some kinda dual pump system. 1 runs the front nozzels 1 runs the back. and because the distance to the back is greater it tends to burn out the rear pump first and u have to replace the whole assembly.
i posted this question a while back about my car. i believe this is close to the answer i was given b4. and its about a $37 part from toyota. -------------------- ![]() Kawi Love |
Jan 25, 2010 - 9:46 AM
Same pump for front/rear. it just spins the opposite way i believe. and many times it will work on the front but not rear
| Lo-Fi Version | Time is now: June 24th, 2026 - 5:03 PM |
