> GB: Braided Stainless steel brake lines, GB Ends Febuary 26th 2010 midnight
post Jan 27, 2010 - 3:06 PM
Reason
Joined Oct 29, '09
From Rhode Island/Japan
This group buy is for your 6th gen Toyota Celica with 4 brake lines (6 and 8 line kits available for other make and models, please PM for pricing). My eBay buyer/seller feedback at the bottom of this post.
So here's the brake down. PTFE Teflon hoses (see below for info), braided stainless steel PVC coated brake lines. These lines are great and popular with Subaru and Honda owners that I dealt with on other forums.
I will offer to you guys first a choice of color (see below) that I never offered to my past customers. That's right custom colors!!!
When you put your name down please tell me year and trim, plus desired color.
*COLORS*
Clear
Black
Blue
Charcoal
Red
Smoke
Green
Yellow
Unfortunately like I said this is the first time I am offering colors and don't have pics. I personally used these lines and love them. I used them on my first Subaru Legacy, and will be getting a set for my motorcycle soon enough!
$125 Shipped
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
$115 shipped (need at least 11 people for this price)
11.
12.
14.
14.
15.
16.
17.
18.
19.
$105 SHIPPED!! (need at least 20 people for this price)
20.
GB End February 26th Midnight! Payments do the next day February 27th. This deal is only good for this period. Orders will ship immediately after all payments are collected. I can not ship before hand since somebody could back out. If all 20 slots are filled and all payments are received before the end date, I WILL ship out early.
If there's and confusion about this GB please feel free to ask here or in PM's. I take PAYPAL only.... And I will do international orders if you cover the shipping.
(if you have another car and want to get SS lines for it pm me please)
Advantages of Teflon
* Chemical Resistant
PTFE is virtually unaffected to practically all commercial chemicals, acids, alcohols, coolants, elastomers, hydrocarbons, solvents, synthetic compounds and hydraulic fluids.
* Temperature Resistant
It can handle it all, from cryogenics to steam all in one hose. Temperature range is from -65¡ F to 450¡ F
* High Flow Rates & Low Friction
Due to the anti-stick properties of the Teflon¨ you will not experience low pressure drops from accumulate deposits on the inner core. Easy to clean permitting use of one hose for several services.
* Flexible & Lightweight
Easier to move, handle and install than rubber hose with a comparable burst pressure rating. Withstands continuous flexing and vibration without failure from flex fatigue.
* Moisture Resistant
No moisture absorption, ideal as a pigtail in bulk gas handling and pneumatic systems where a low dew point is critical.
* Non-Adhesive
Handles substances such as adhesives, asphalt,dyes, greases, glue, latex, lacquers and paints with ease.
* Chemically Inert
Will not break down or deteriorate in service.
* Non-Aging
Impervious to weather and can be stored for extended periods of time without aging. It will not age during service.
* Shock Resistant
Not affected by continuous flexing,vibration or impulse pressures - withstands alternating hot and cold cycling.
Polytetrafluoroethylene is an engineered fluoropolymer commonly known by DuPont's trade name "Teflon". Outstanding resistance to chemicals is one of it's primary attributes. A broad temperature range of -100F to 500F
(-73C to 260C) make this hose material suitable for the majority of fluid and ambient temperature conditions found in industry. An extremely low coefficient of friction, (0.05 to 0.20), provides a non-stick surface. Water absorption of PTFE is negligible, less than 0.01% by ASTM test. And, it is FDA-approved for food and pharmaceutical use.
Smooth Bore PTFE "Teflon" inner core Hose
* Inner core vertically extruded to maintain highest quality concentricity.
* Manufactured from DuPont's type 62 fine grade resin.
* 304 stainless steel wire braid reinforcement.
* An exact amount of carbon black added to the PTFE inner core provides
continuous conductive path to the metal end fittings, to bleed off static
electricity in steam or high flow rate applications.
* For continuous service: -65¡F to 450¡F (-54¡C to 232¡C)
* For intermittent service: -100¡F to 500¡F (-73¡C to 260¡C)
* Meets or exceeds requirements of SAE 100R14
* PTFE meets FDA 21 CCFR 177.1550
* Sizes -4 thru -10 are rated for full vacuum.
* Larger sizes -12 and above can be reinforced with an internal support spring for
full vacuum service.
Physical Characteristics:
* Tensile strength: 3,500 psi
* Elongation: 250% min
* Dielectric Strength: 1,000 volts per mil
* Softening point: 500F (260C)
NOTE*
If this works out I will do one for clutch lines as well.
http://feedback.ebay.com/ws/eBayISAPI.dll?...mp;myworld=true
My Subaru Legacy forum
www.SL-i.net
I don't have much history for seller here but you can check my feedback as I go on.
Year - Model - #of lines
86-89 CELICA 4
86-89 CELICA 4
88-89 CELICA ALL TRAC TURBO 4
90-93 CELICA 4
90-93 CELICA 4
90-93 CELICA ALL TRAC TURBO 4
94-12/97 CELICA 4
94-99 CELICA 4
00-05 CELICA GT 4
00-05 CELICA GT-S 4
This post has been edited by Reason: Jan 27, 2010 - 4:38 PM
Replies (1 - 4)
post Jan 27, 2010 - 3:32 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
So if I understand correctly, these are *not* for 6th gen Celicas?
post Jan 27, 2010 - 3:58 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I PM'd him asking about this.
post Jan 27, 2010 - 4:30 PM
Reason
Joined Oct 29, '09
These are 6th gen Legacy specific. I was just going to open the GB for ALL Celica years. I can get SS brake lines for pretty much any car. Sorry for the confusion, like I sold Spider77 I was half asleep when I wrote this, it was a LONG night. It should be more clear now.
post Jan 27, 2010 - 5:27 PM
You need to get approval from Christian or myself to run a GB here on 6gc.
Just another heads up , you will only be allowed to sell 6th gen Toyota celica items here.
You can also get normal SS barke lines on eBay for ~60 so double the price gets us pretty colored lines?
Closed TopicStart new topic
Lo-Fi Version Time is now: June 21st, 2026 - 1:46 PM
