> 8 pin rear foglight, need diagram
post Jan 28, 2010 - 12:29 AM
yagamius
Joined Feb 18, '09
From Costa Rica
I just got my rear fog light I will use it to control my front fogs. biggrin.gif
I know this is some where, i checked like 10 pages and try to search it but not luck kindasad.gif , so if someone can help me with the 8 pin diagram and which color wire is for what will be great.
thanks everyone
1994 ST Celica --> no swap --> 7A rebuild
1974 Mustang --> Almost Restored
post Jan 28, 2010 - 8:04 AM
azian_advanced
Joined Apr 18, '05
From Calgary
have you checked this thread?
UK spec OEM fog light switch/button (see the last few posts of page 4 and all of p. 5)
post Jan 28, 2010 - 1:09 PM
yagamius
Joined Feb 18, '09
From Costa Rica
QUOTE (azian_advanced @ Jan 28, 2010 - 7:04 AM) *
yes I checked and found what the colors are but not the diagram, the diagram is for the 6 pin kindasad.gif
post Jan 28, 2010 - 1:55 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
post Feb 2, 2010 - 7:32 PM
DGAF
Joined Nov 27, '09
From New York USA
QUOTE (GriffGirl @ Jan 28, 2010 - 2:55 PM) *
post Feb 2, 2010 - 11:15 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
take it apart! wooo
Breaking Axles...
post Feb 2, 2010 - 11:21 PM
GriffGirl
Joined Feb 7, '07
I'm actually going to endeavor to figure this out this weekend. I REALLY REALLY want my switch! smile.gif
post Feb 3, 2010 - 2:37 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
I have one on order right now. Not sure if it's eight pin or six pin, should be eight pin. I'll post up what I find out when I get it.
post Feb 3, 2010 - 2:38 PM
GriffGirl
Joined Feb 7, '07
Yessssssssss
post Feb 8, 2010 - 5:46 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Just got the switch in the mail from jolly old England. It's 8 pin and has the harness with it. I have tomorrow off so I'll take it apart and see what I can find out.
This is a little silly for me since I don't have fogs on the car yet. Not sure if I want to hook up the rears like the factory either. I'm sure I'll find something to do with it.
post Feb 8, 2010 - 6:12 PM
GriffGirl
Joined Feb 7, '07
post Feb 20, 2010 - 4:06 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
So I've been messing around with the switch since I got it with limited results. Of course the first thing I did was swap the light for a blue led.
Right now I have it hooked up with +12V going to the green/red and the green wire. The white/green, white/black, green/black, and red/yellow are all grounded. When I push the button the red wire goes from +.6V to +12V.
Can't seem to get the red/black wire to do anything.
I suppose that you could run the red wire to a relay to get it to switch on the fogs as well as switch on the light on the dash.
I did notice that the switch would not work without +12V going to the illumination wire (green). It must use that for more than just the illumination.
post Feb 21, 2010 - 2:37 PM
Driveby
Joined Sep 17, '05
From Newcastle / UK
Thanks for this, my car is JDM but being used in the uk it requires rear fog lamps and had an aftermarket switch fitted. I acquired a uk spec switch and harness this week and was just looking for this information.
Cheers!
1994 JDM GT4 WRC
post Feb 22, 2010 - 3:43 PM
yagamius
Joined Feb 18, '09
From Costa Rica
QUOTE (RocketScott @ Feb 20, 2010 - 3:06 PM) *
nice great improvement, I try to find out why so many wires but not luck yet kindasad.gif
post Feb 22, 2010 - 5:43 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (RocketScott @ Feb 20, 2010 - 4:06 PM) *
this does make sense... illumination (green wire) only has power with lights on.... therefore... you could only activate rear fog lights when your lights are on...
Breaking Axles...
post Feb 23, 2010 - 5:40 AM
zoik
Joined Aug 28, '07
From france
hum if this can help, ill try to take a pictue of mine this afternoon (euro spec)
post Mar 11, 2010 - 3:39 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
So here is what I have been working with. The wires are going 1-8 right to left. To get it to work for simply switching a relay only six wires need to be used.
1. Output 12v to relay
2. +12v from illumination
3. +12v
4.
5.
6. Ground
7. Ground
8. Ground
post Mar 11, 2010 - 7:54 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I'll be keeping an eye on this, as I should have one coming in myself (not sure which one it is)
post Mar 12, 2010 - 3:10 PM
GriffGirl
Joined Feb 7, '07
With the numbering you have there, is that exact to the pin numbers? Because I have the switch, but not the wiring thing that plugs into the back of it, so I'll have to put something together myself.
post Mar 12, 2010 - 6:13 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Yes those are the actual pin numbers. Same as the other posts about the switch.
On a side note I installed mine yesterday and had to trim the switch to make it fit. Not sure if it's because I have a '94 and the 8 pin switch was for later years or not.
Lo-Fi Version Time is now: August 25th, 2026 - 12:12 AM
