Feb 3, 2010 - 10:29 AM
Enthusiast Joined Jan 25, '10 From Manila, Philippines Currently Offline Reputation: 0 (0%) |
i got a 98 Celica liftback.. its my first oil change and im having a problem with the oil filter. i hope u guys u can help me out what kind of oil filter to use, where to find it and how to install it. i hope u can give me some advice, im a newbie with it comes to car maintenance. thanks!
Feb 3, 2010 - 2:03 PM
Enthusiast ![]() Joined Sep 16, '08 From Michigan Currently Offline Reputation: 0 (0%) |
If you just go to your local Autozone or any dealer that sells the related things that you can just tell them what engine you have/year/car (engine is from) and anything else they ask they will give you a number of which oil filter to get or they will give it to you. Just tell them that you need an oil filter and they will ask you what car what engine what year, etc..
Feb 3, 2010 - 5:06 PM
Enthusiast Joined Sep 1, '07 From Denmark Currently Offline Reputation: 0 (0%) |
you just need one of the most common Toyota oil filters ever for your 98 Celica 3SGE
Parts number 90915-10001 Also known as 90915-YZZJ1 How to change it, hmm, well its just drain the oil from the bottom of the engine by removing the bolt there, remember to change that little gasket on the bolt, it's same gasket on all Toyotas and Lexus Then to change the filter you need to remove a plastic cover underneath the engine on the right hand side, if the oil filter is too hard fastened there's some cheap tools made for loosening oil filters When installing the new oil filter, you don't need to put oil on the oil filter gasket, as Toyota already applied lubricant at the factory Good luck Before starting engine, refill 4.5 liter of 10W-40 oil and you should be good to go This post has been edited by BocaJ: Feb 3, 2010 - 5:07 PM |
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:37 AM |
