> grinding near break assy, intresting issue~
post Feb 3, 2010 - 9:48 PM
D-Man
Joined Jan 18, '08
From Houston
Okay; so check this out;
it didn't happen first thing after the swap; but slowly emerged (within a week). quietly at first; but now it's getting really fcuking loud. I've already droped the tire and reallined the break/dust shield several times, (not the issue); then (remembering the D/S rotor conversion) i've swaped the pads arround (thinking they could be backwards), cleaned em (they had alot of debreis, but that may be unrelated) I've re-positioned the clips; i've remounted the tire a few times... (*NOTE: i have replaced the missing lugnuts the swap-shop fcuking lost...) yet this problem persists...
last though is that maybe there is insufficient grease in the hub boot where it hits the bearing?
here guys, listen for yourselfs!!
(only watch the first few seconds of this first one, afterwords, we're making our plan and my photographer was oblivious to the "end-video" key. enjoy our conversation... lol)
http://www.youtube.com/watch?v=arIU_KJy6H4
http://www.youtube.com/watch?v=I1vdpGx6ZkQ
IDEAS?!?!
Damn D-Man - most impressive.
- D-Man   grinding near break assy   Feb 3, 2010 - 9:48 PM
- - SwissFerdi   "This video is private." I'd like t...   Feb 3, 2010 - 10:37 PM
|- - D-Man   QUOTE (SwissFerdi @ Feb 3, 2010 - 9...   Feb 3, 2010 - 11:35 PM
- - njccmd2002   poorly lubricated muffler bearings   Feb 4, 2010 - 1:39 AM
- - Bitter   check the wheel bearing, it sounds like it could b...   Feb 4, 2010 - 7:38 AM
|- - D-Man   QUOTE (Bitter @ Feb 4, 2010 - 6:38 A...   Feb 4, 2010 - 7:41 AM
- - Bitter   any other sounds at higher speeds? roaring, rumbl...   Feb 4, 2010 - 7:54 PM
- - D-Man   again man, it's in revolution to the turning o...   Feb 4, 2010 - 11:46 PM
- - Bitter   sadly the only way to look at the wheel bearing is...   Feb 5, 2010 - 9:10 PM
- - Hanyo   does the car make that sound with the wheel in the...   Feb 5, 2010 - 9:38 PM
- - D-Man   well it's definitely giving off the tattle tal...   Feb 5, 2010 - 10:01 PM
- - easternpiro1   you were talking to your girl (beyotch?) so nicely...   Feb 6, 2010 - 2:42 AM
|- - D-Man   QUOTE (easternpiro1 @ Feb 6, 2010 - 1...   Feb 6, 2010 - 10:11 AM
- - Bitter   they should come pre-lubed and are pressed into th...   Feb 6, 2010 - 11:21 AM
- - D-Man   well; turns out that my bearing were totaly molest...   Feb 6, 2010 - 8:56 PM
- - Bitter   good work, but...and i'm sorry but theres a bu...   Feb 7, 2010 - 2:58 PM
|- - D-Man   QUOTE (Bitter @ Feb 7, 2010 - 1:58 P...   Feb 7, 2010 - 3:43 PM
- - Bitter   taking them apart like that is easy, problem is yo...   Feb 7, 2010 - 8:41 PM
- - easternpiro1   might i add good buddy, that you SHOULD NOT UNDER ...   Feb 7, 2010 - 11:53 PM
|- - Hanyo   QUOTE (easternpiro1 @ Feb 7, 2010 - 8...   Feb 8, 2010 - 5:45 AM
- - Bitter   pepboys has SKF or Timken, both very good quality.   Feb 8, 2010 - 8:37 PM
- - D-Man   QUOTE (Bitter @ Feb 7, 2010 - 8:41 P...   Feb 8, 2010 - 9:00 PM
|- - Bitter   QUOTE (D-Man @ Feb 8, 2010 - 9...   Feb 9, 2010 - 5:47 AM
- - easternpiro1   QUOTE (Hanyo @ Feb 8, 2010 - 6:45 AM...   Feb 9, 2010 - 1:01 AM
Lo-Fi Version Time is now: August 26th, 2026 - 12:32 PM
