Feb 9, 2010 - 3:04 AM
Enthusiast ![]() Joined Dec 2, '09 From Chino Hills, CA Currently Offline Reputation: 8 (100%) |
not sure if this is in the right section but i was wondering how to remove the fuse box under the hood cause i want to adjust my left headlight but its just too tight down there..any help?
Feb 25, 2010 - 4:38 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
did you figure it out?
Feb 25, 2010 - 4:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 22, '04 From FL Currently Offline Reputation: 1 (100%) |
I dont remember if gt and st boxes are the same but to get you started you would have to disconnect your battery and slide it to the left. Then remove fusebox lid. there should be a couple of screws on inside as well as one or two on the side. You will not be able to totally remove the fusebox since its attached by wires but it will give you wiggle room to do your project.
-------------------- Captain Pessimist
Feb 25, 2010 - 6:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
I got my hands down there...tight fit though. Used a 1/4 inch drive with a deep socket IIRC. Although im sure that it would of been easier with a swivel socket.
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:40 PM |
