Feb 21, 2010 - 6:21 PM
Enthusiast ![]() Joined Sep 11, '09 From NYC Currently Offline Reputation: 2 (100%) |
Hey, so I was getting ready to show my car to a buyer and thought maybe I should test drive and all beforehand. After driving for a few mins, I pull out my SAFC2 and go through the categories. I go to car select and it asks the cylinder and its set at 4 and the Up arrow, but I accidentally changed it and it went to down and then the two stars, this is all while the car is at idle. When it changed to the down, the car started to bog down and the idle got rough, I immediately changed it back to Up and exit the screen back to the main menu.
I don't know if what happened after was the cause of my stupidity, but the car started to idle really rough and low to the point where it feels like its stalling, then the car stalled. When I restarted the car back up the idle was rough and low and felt like it was going to stall. I press on the gas and it would bog and then stall. I look at my boost gauge and there seems to be a vacuum leak or something because it's reading around 10, usually it's at 21. I look under the hood, and i smell fuel and see some fumes coming from around the IM area. I think its the fuel injector area and near the throttle body area as well. I am really not sure what the problem is. I now have a CEL and when i drive, i can hear a big vacuum leak, kinda sounds like im spooling and if i let go i hear either my wastegate or a psssh sound. Anyone have any idea what this can be? I am confused and really upset because I was just about to sell this and this happens. Cliff: My car idles rough, low rpm idle, stalls at times when i press the gas, CEL is on, car sounds like a constant BOV or boost leak while driving. Couldn't find any vacuum leak anywhere. |
ravinaziankid I Need some help Feb 21, 2010 - 6:21 PM
SlvrCelica09 QUOTE (ravinaziankid @ Feb 21, 2010 - 6... Feb 22, 2010 - 12:48 PM
lagos QUOTE (ravinaziankid @ Feb 21, 2010 - 6... Feb 22, 2010 - 10:43 PM
ravinaziankid This is for a 5sfte, I haven't gotten a chance... Feb 23, 2010 - 12:17 AM
lagos QUOTE (ravinaziankid @ Feb 23, 2010 - 12... Feb 23, 2010 - 12:22 AM
ravinaziankid The swap was done by the previous owner and some m... Feb 23, 2010 - 12:27 AM
bccentaur3 Count the flashes and get back to us. We'll le... Feb 23, 2010 - 3:36 PM
playr158 Issue is mostly likely the SAFC Feb 23, 2010 - 4:06 PM
_Jim_ It is very possible that you turned the correction... Feb 23, 2010 - 4:20 PM
ravinaziankid OK, I will give that a try..yeah it all happened a... Feb 23, 2010 - 4:23 PM
ravinaziankid I feel dumb now..it was on the wrong sensor settin... Feb 23, 2010 - 4:44 PM
_Jim_ Its actually fairly easy when messing with the SAF... Feb 23, 2010 - 5:03 PM
ravinaziankid Thanks again..this is one of the best forums for i... Feb 23, 2010 - 5:13 PM
SlvrCelica09 glad you got it fixed.. wish it was that easy f... Feb 23, 2010 - 10:22 PM
lagos QUOTE (SlvrCelica09 @ Feb 23, 2010 - 10... Feb 23, 2010 - 11:00 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 1:42 PM |
