Feb 23, 2010 - 3:06 PM
Enthusiast ![]() Joined Apr 2, '07 From Calgary, Alberta Currently Offline Reputation: 1 (100%) |
My thermostat seems to be toasted.
The car would indicate that it's below the C line even after driving for 30 mins It would means that the car is running rich and have a high idle to protect the "cold" engine right? my quesiton is is there a guide to for thermostat replacement on the GT-four? I got the ST205 & 3SGTE repair manual supplement pdf is the thermostat the same as the "intake air temperature sensor"? Anyone have the parts number for the 3s-gte thermostat? I come from a pretty cold place so I don't think I'll need a TRD low temp thermostat. This post has been edited by Artega: Feb 23, 2010 - 3:20 PM |
Feb 23, 2010 - 3:32 PM
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
http://toyotaownersclub.com/forums/index.p...mp;#entry710379
http://wiki.answers.com/Q/How_do_you_repla...1993_Toyota_MR2 Thermostat: 90916-03100 ***Thermostat: 90916-03117 (Substitute: From Land Cruiser) Both thermostats fit. -------------------- |
Feb 24, 2010 - 1:14 AM
^ good info on the landcruiser
Feb 24, 2010 - 10:55 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
does your heater blow hot air?
Feb 24, 2010 - 2:06 PM
hardly
and not when the temperature gauge shows C it does blow hot air after driving around for a while, then idle for 5 mins the gauge would show it's warming up and start blowing hot air then I would go driving and the gauge would show it's cooled down and no more heat. so I'm guessing the thermostat is stuck open. |
Feb 24, 2010 - 2:31 PM
Yep, I think you're right on the money there about the thermostat being stuck open.
Feb 27, 2010 - 8:40 PM
oops
I guess i need to buy the gasket as part of the replacement. Sounds like as part of the repair I'll need to drain and replace the radiator fluid? |
Feb 28, 2010 - 12:36 AM
oops I guess i need to buy the gasket as part of the replacement. Sounds like as part of the repair I'll need to drain and replace the radiator fluid? Yep and some will come out, a decent amount, it's just a good thing to go ahead and change out your fluid if it's been a while anyways. -------------------- |
| Lo-Fi Version | Time is now: July 29th, 2026 - 3:54 PM |
