Feb 25, 2010 - 12:59 AM
Enthusiast Joined Feb 21, '10 From St.Louis Currently Offline Reputation: 0 (0%) |
+ shipping for everything listed.
Pics of specific parts upon request. ChrisK Intake Manifold + Ford 70mm TB $600 LSD Axles w/ATS Chromoly axle cages (rebuilt within last 2 years) $625 LSD Transmission $750 KO Racing Intake w/ 3inch inlet $130 KO Racing SB 50. trim kit (Turbo has less than 1000 miles on it, new diaphragm) $1675 3rd gen ECU $300 Berk SMIC $350 ATS 9" Puller fan $110 ST205 A2W IC Core $310 3rd gen Catyltic Converter $25 3rd gen Throttlebody $65 3rd gen ECU $225 3rd gen MAP sensor $200 stock 3rd gen intake manifold $185 stock 3rd gen exhaust manifold $65 ST205 a/c compressor $50 ST205 p/s pump $50 top half Oil pan $100+ Bottom half Oil pan $35 3rd gen short Block (rod knock) $200 Red powdercoated 3rd gen valve cover $80 Cams $100 Cam gears $60 Dip stick $20 Oil Cooler $40 This post has been edited by 3sgtepower: Feb 25, 2010 - 1:33 AM |
Mar 25, 2010 - 2:30 PM
Enthusiast Joined Dec 11, '09 From san ramon, ca Currently Offline Reputation: 0 (0%) |
do you have the plastic piece between the throttle body and the a2w ic for the st205?
+ shipping for everything listed. Pics of specific parts upon request. ChrisK Intake Manifold + Ford 70mm TB $600 LSD Axles w/ATS Chromoly axle cages (rebuilt within last 2 years) $625 LSD Transmission $750 KO Racing Intake w/ 3inch inlet $130 KO Racing SB 50. trim kit (Turbo has less than 1000 miles on it, new diaphragm) $1675 3rd gen ECU $300 Berk SMIC $350 ATS 9" Puller fan $110 ST205 A2W IC Core $310 3rd gen Catyltic Converter $25 3rd gen Throttlebody $65 3rd gen ECU $225 3rd gen MAP sensor $200 stock 3rd gen intake manifold $185 stock 3rd gen exhaust manifold $65 ST205 a/c compressor $50 ST205 p/s pump $50 top half Oil pan $100+ Bottom half Oil pan $35 3rd gen short Block (rod knock) $200 Red powdercoated 3rd gen valve cover $80 Cams $100 Cam gears $60 Dip stick $20 Oil Cooler $40 |
Mar 27, 2010 - 12:53 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Wow... nice! BUMP
June '12 COTM '95 AT200 |
| Lo-Fi Version | Time is now: May 6th, 2026 - 5:04 PM |
