Feb 26, 2010 - 1:53 AM
Enthusiast ![]() Joined Dec 2, '09 From Chino Hills, CA Currently Offline Reputation: 8 (100%) |
so i installed an aftermarket headunit..a cheap kenwood just for my subs..and whenever i put on the radio...its all static and my antenna does not raise at all...any help? thanks
Feb 26, 2010 - 2:29 AM
make sure you connected your antenna to the back of the deck!
Feb 26, 2010 - 3:07 AM
Enthusiast ![]() Joined Apr 5, '09 From B.C. Coquitlam Currently Offline Reputation: 5 (100%) |
our radio antennas are powered so they wont extend unless they get power from your headunit, which could be why your getting bad reception?
Feb 26, 2010 - 3:48 AM
Enthusiast ![]() ![]() Joined Dec 16, '07 From Chicago, IL Currently Offline Reputation: 10 (100%) |
connect the head units antenna wire to the cars auxiliary wire
This post has been edited by SoDo: Feb 26, 2010 - 3:50 AM -------------------- 1999 Celica GT Hatchback
Mar 1, 2010 - 9:59 PM
thanks for the help guys..i think theres no input for the antenna wire to go to the back of the headunit. no worries..did my s2k antenna swap and radio works fine now
Mar 29, 2010 - 6:01 PM
Enthusiast ![]() ![]() ![]() Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) |
Sorry to hijack your thread but I have radio problem too and don't want to start a new thread:
Time to time my radio completely resets on the start of the car (i.e. loose all the settings, presets etc.) I have professionally soldered and insulated all the harness connection (no crimping) and double-checked everything. No loose ground. Anybody has experienced similar glitch? -------------------- '94 ST |
Mar 29, 2010 - 8:12 PM
Sorry to hijack your thread but I have radio problem too and don't want to start a new thread: Time to time my radio completely resets on the start of the car (i.e. loose all the settings, presets etc.) I have professionally soldered and insulated all the harness connection (no crimping) and double-checked everything. No loose ground. Anybody has experienced similar glitch? i also had this problem on one install. your 2 power wires 12v and ignition may be reversed. you will lose all settings if the constant power supply is wired to ignition because uhh ignition isnt constant haha |
Mar 29, 2010 - 10:27 PM
Sorry to hijack your thread but I have radio problem too and don't want to start a new thread: Time to time my radio completely resets on the start of the car (i.e. loose all the settings, presets etc.) I have professionally soldered and insulated all the harness connection (no crimping) and double-checked everything. No loose ground. Anybody has experienced similar glitch? i also had this problem on one install. your 2 power wires 12v and ignition may be reversed. you will lose all settings if the constant power supply is wired to ignition because uhh ignition isnt constant haha I will definitely check on that but I don't think so. That would cause the stereo to reset EVERY time but my problem is "hit and miss". -------------------- '94 ST |
Mar 29, 2010 - 10:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Wobbly connection at power source?
This post has been edited by SwissFerdi: Mar 29, 2010 - 10:32 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Mar 30, 2010 - 11:01 AM
Enthusiast ![]() ![]() ![]() Joined Jan 10, '09 From Burtonsville, Maryland Currently Offline Reputation: 1 (100%) |
i also had this problem on one install. your 2 power wires 12v and ignition may be reversed. you will lose all settings if the constant power supply is wired to ignition because uhh ignition isnt constant haha this should be the reason. if you have a non name brand head unit these 2 wires are confused 100% of the time. GL -------------------- THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma.. 6gc.net's outlaw vigilante because im a LEADER not a follower. ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 2:47 AM |
