> Building the 7A-FE, Lots of pics!!!!!!!
post Mar 2, 2010 - 6:20 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
Well i rebuilt Eryn's ST last weekend. I took as many pictures as I could
Here is the block, all pretty and blue
The underside of the block and where the main bearings are installed
These are the main bearings, old on the left and new on the right. make sure you use the same size and plastigauge to double check clearances
Main bearing installed
Plastigauge on the main journals, do this on every journal
Install Main caps in order, look at the number and arrow is pointing to #1 Torque to 44lbs
remove caps and check clearances. .0015" clearance is good!
Remove crank and clean off plastigauge, apply assembly lube generously
Lay crank back on bearings and apply more lube
More lube on main cap bearing, my daddy always says, you can never have too much lube smile.gif
rod cap, make sure you line them up and install the correct cap on the rod
This is the wrong match you want an M not a goofy looking triangle like this
More lube on the rod bearing
Using a spring compressor, install the piston and rod assembly
make sure you install the correct piston according to the mark on the block. This is actually wrong. #1 piston in a #2 spot. you can see the marks on the block in the circle
Piston installed (wrong one...oops)
Take one of the old rings and break it, use this piece to clean the gunk out of the ring lands
Top of dirty piston, i didnt get a pic of it after i cleaned it
Marks on the block to identify piston size
Another shot of the wrong cap and rod together Do not do this!
Crap collected in ring lands, look at the oil ring, this is why you burn oil, the ring is too gunked up to expand
Cleaned out piston
Damaged bearings
Amazingly the crank was fine, look at the bearing!!!!!
New piston installed, the old one had some damage on it. Something bad happened in this engine
Head all cleaned up
Removing the keepers and retainers, I use a socket and smack it with a dead blow hammer.
Look at these exhaust valves, nastyness!
After a good cleaning on the wire wheel
These are the valve guide seals, most of them fell apart like this when removed. another reason for burnign oil and smoking
Intake valve, look at the awesomeness collected on there, think flow imporved after a good cleaning?
These are the marks on the crank to identify what main bearing to install
This is the new oil pump gasket
Oil pump installed
#1 oil pan after a good sand blasing
These numbers on the bottom of the block also identify what piston to install
These numbers match up with the numbers on the crank to identify what main bearing to install
Cleaned up rear main seal housing
Seal before pressed into housing
On an engine stand this area is a little tight, but you can get in there
New gasket for rear main seal
Rear main seal installed
Install #1 oil pan, originally these 2 bolts were hex bolts, PITA to get out so i replaced with regular bolts
Here you can see the hex bolts and regular bolts that are used to secure the oil pan
New oil pickup gasket
Install oil pickup
Install windage tray
Install #2 oil pan
Top view, pistons installed. Make sure assembly rotates
Install new head gasket
Install head on block, torque head bolts to 22 lbs in specific order, then turn each bolt 90 degrees, then turn each bolt another 90 degrees
Insert shimm and bucket assembly, I oopsed in this pic also, got them backwards
Right shimms installed, exhaust cam in position
Install new cam seal
Check timing marks, make sure the dots line up during the cam rotations
New water pump seal
New water pump
Install crank timing gear
You can barely see the indent on the gear that lines up with that small dot on the oil pump, these are timing marks
New idler pully
Tighten pully out of the way like so
Here you can see the timing marks
Once belt is installed, release tensioner and then re-tighten it
I lose my scribe so pics will be less detailed frown.gif here are the timing covers installed and water pump pully
installed AC bracket and alternator bracket
Intake manifold is installed back on, clean surface of water sensor pipe
Apply FIPG on sensor pipe
Installed on head
this is the power steering pump bracket
Install wiring harness back on the engine
Install cover plate, sorry i dont have pics for flywheel and clutch install, then bolt tranny to block
Lowering assembly into engine bay.
Sorry i dont have any more pics. i lost my scribe and i was install mode. I didnt have time to take pics and write down details. Engine is running smoothly and has quite a bit of pep for a 7A-FE. Turbo install will be coming next in the near future.
phew, ill add detailed comments tomorrow
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 2, 2010 - 6:38 PM
I don't know half of what I'm looking at...but I can tell that it's some thorough work. Very nice.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Mar 2, 2010 - 7:01 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
Smaay,
This is one of the most complete motor build-ups I've ever seen...definitely on par with the BGB for the Celica. If you don't mind, how much time has this rebuild required so far?
Has no more Celicas
post Mar 2, 2010 - 7:08 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
Sweet thumbsup.gif i have a few questions though:
How many miles on the 7a?
What all did you replace/where did u get the parts?
Tools needed(dont need to list mm of sockets tongue.gif laugh.gif )
Time?
This post has been edited by CelicaST_CALI: Mar 2, 2010 - 7:09 PM
BANNED. for life, you moron.
post Mar 2, 2010 - 7:23 PM
kormysh8
Joined Nov 14, '09
From Saskatoon
this should for sure be in the "how to" article section. thanks. pretty detailed. this will help a lot for my next project. thanks man thumbsup.gif
post Mar 2, 2010 - 7:28 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
where is the "how to" section?You mean the stickies?Cause only moderators can put threads in there
post Mar 2, 2010 - 8:24 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
I pulled the engine and tore it down in 1 day. had to wait a week for the parts to come in from the dealer. the piston and bearings got back ordered from the dealer. I only use OEM parts from the dealer. i rebuilt the engine and installed it in the car in 1 day.
The original miles were 92K and tools uses were standard 10mm, 12mm, 14mm, 17mm sockets, some needle nose pliers, torque wrench, and a few screwdrivers here and there to poke things. nothing really special needed except the hoist and engine stand.
post Mar 2, 2010 - 8:28 PM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
AMAZING! AMAZING !! I am so excited to get my car back. You did such a great job I appreciate all your efforts soooo much!!!! Plus I learned alot even about tools lol espically sockets!! laugh.gif biggrin.gif!!!!!!!
The heart has its reasons which reason knows nothing of
2000 7th gen GTS 6spd
95 st, swapped 3sgte 3rd gen wrc version :D
post Mar 2, 2010 - 10:01 PM
xtinkt94
Joined Jan 24, '09
From Olney IL
Except for the blue paint this is exactly what I am getting ready to do to my boys car. Finding the rebuild kit is going to be the hard part for me since I'm at least 45 miles from the nearest Toyota dealer.
Never take advice from someone who is not doing better than you
post Mar 2, 2010 - 10:33 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
very cool, wish I had the balls to pull my engine out and attempt that, how many km were on the original engine?
post Mar 2, 2010 - 11:06 PM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
QUOTE (Euphoria @ Mar 2, 2010 - 11:33 PM) *
92,000 not very many
92,000 miles not very many
post Mar 3, 2010 - 1:18 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (xtinkt94 @ Mar 2, 2010 - 7:01 PM) *
there are several toyota dealers that will ship parts. 1sttoyotaparts.com i thing is one of them. the engine rebuild gasket kit is about 230 bucks and it comes with every gasket you will need. plus some you dont.
post Mar 3, 2010 - 10:03 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (Smaay @ Mar 2, 2010 - 9:24 PM) *
you didn't send the block out to be honed and the head to be machined true?
post Mar 4, 2010 - 10:30 AM
Delta_Phoenix
Joined Oct 16, '02
From Hohenwald, Tennessee
QUOTE (Bitter @ Mar 3, 2010 - 9:03 PM) *
Awesome post and very informative, but I'm also wondering the same thing...
post Mar 4, 2010 - 4:10 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Bitter @ Mar 3, 2010 - 7:03 PM) *
i have a honing tool so i did that myself. the head was checked with a straight edge, good and flat, so was the deck.
This engine is only going back in till she can save up for the 3S-GTE swap. but we have to finish the turbo install on her 7th gen first.
post Mar 5, 2010 - 4:58 AM
windowlicker
Joined Jul 2, '08
From SoCal
so this is what eryn has been up to...
post Mar 5, 2010 - 2:38 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
good stuff smaay!oh the 7a... it lives! haha!
post Mar 5, 2010 - 9:03 PM
Bitter
Joined Mar 11, '06
QUOTE (Smaay @ Mar 4, 2010 - 4:10 PM) *
got it, i figured it was a 'hold over' rebuild' anyways. i didn't know how deep you were getting into it or not. looks nice! mad powa from the 7a now!
post Mar 5, 2010 - 10:34 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
today we installed a muffler canister. the sound was amazing, nice deep and throaty! we also advanced her timing to about 14 degrees and she is stuck on 91 gas now. but the power increase was nice
post Mar 6, 2010 - 12:22 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
I LOVE the sound of the 7A. I miss mine dearly. She's there in the garage all lonely. frown.gif
Lo-Fi Version Time is now: September 11th, 2026 - 7:42 AM
