> distributer problem possibly, car wont start
post Mar 16, 2010 - 4:30 PM
TerBeau
Joined Nov 25, '08
From dillsburg pennsylvania united states
i just put in a motor in my celcica and its not getting spark. i put a test light in the coil and it dont pulsate but it turns on. can anyone tell me if its supposed to pulsate? and if anyone had this problem before help me out please. im buyign new cap and rotor and plugs and wires tomorrow but it still wontfix my issue. poss a crank sensor?
those with golf balls golf
those with real balls race
Replies (1 - 5)
post Mar 16, 2010 - 5:58 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
There's stickies on the top of this section of the 6gc Forum
one of the threads will show you this sticky:
http://www.celicatech.com/imagearchive/bgb...odes%202.2L.pdf
Go to page 19 on the PDF file and follow the instructions for the CEL #12 for distributor resistance. This will tell you if your Distrib is GAY thumbsup.gif
The crank sensor is near the oil pump housing........so HOPE its not the problem.
Start with the Distrib ^^ then move on to the Ignition Module, the the connectors on the ECU.
Cheapest Part ---Most expensive
post Mar 16, 2010 - 7:29 PM
TerBeau
Joined Nov 25, '08
QUOTE (808celica @ Mar 16, 2010 - 5:58 PM) *
post Mar 17, 2010 - 2:59 PM
TerBeau
Joined Nov 25, '08
ok found my prob. took me a lil till i relized this. 95 1.8 motor into a 96 celica!! what changed? lol i need a crank postion sensor the 95 1.8 had a cam position sensor in the distributer so i seen that extra plug and didnt thinkn anything of it soo i pulled the ditributer out put in a 96 distributer and totally forgat (i need a crank position senor) duhhhh hahah
post Mar 17, 2010 - 3:40 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
crank sensor near/in the oil pump housing
cam sensor in the distrib
post Mar 17, 2010 - 3:58 PM
TerBeau
Joined Nov 25, '08
QUOTE (808celica @ Mar 17, 2010 - 4:40 PM) *
Yes. Crank sensor is what is needed the cam sensor is not used on the 96 year That is what I didn't realize
Lo-Fi Version Time is now: June 22nd, 2026 - 4:58 PM
