Mar 17, 2010 - 10:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
what are we really adjusting....which parts....the bottom rings or the top rings...does anyone have pics? of the lowest settings for front and back?
which to adjust? This bottom part only (the BLACK RING) or the part where my THUMB is touching? ![]() The orange rings.....? ![]() What about the space between my two fingers? ![]() What are the right adjustable height of the bottom black piece and the space with thread from orange rings? the displacements? This post has been edited by chacha: Mar 21, 2010 - 10:22 AM |
Mar 18, 2010 - 7:29 AM
The orange rings you adjust so that the spring sits snug up against the top perch.
So push the spring up till it stops, and spin the upper orange ring till it touches the spring, now spin the bottom orange ring up till it meets the upper one. tighten the bottom ring to the top. This is setting pre-load on the spring. the bottom black ring, this is what is allowing your ride height to change. You spin the assembly (the threaded part that your fingers aren't touching) into the base piece (your thumb is touching). make sure you have the same amount of threads into the base, as its partner assembly (left and right must be equal). once you've gotten how low you want to go you snug the black ring down to the bottom piece to hold it in place. (finger to thumb) sounds a bit confusing i know. |
Mar 18, 2010 - 12:22 PM
i understand what you mean...thanks....this took me almost 3 hours to do just the front because....well i didn't know what i was doing....thanks playr; i just did one and match the other in heights
This post has been edited by chacha: Mar 18, 2010 - 12:24 PM |
Mar 18, 2010 - 12:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
damn you and your newer version of the kontrols
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 18, 2010 - 1:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
^ I noticed that too, the build quailty looks really good!
Mar 18, 2010 - 1:58 PM
i understand what you mean...thanks....this took me almost 3 hours to do just the front because....well i didn't know what i was doing....thanks playr; i just did one and match the other in heights don't drive like that much at all. they will react very very differently. |
Mar 18, 2010 - 7:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
they are nice...mine are slammed till the sleeve almost hits the cv boot...only prob i have been having are the front locking nuts underneath the spring keep coming loose...my solution was simple....hose clamp below the lower locking nut...
Mar 18, 2010 - 10:35 PM
Enthusiast ![]() Joined Jan 30, '07 From canada,montreal Currently Offline Reputation: 2 (100%) |
from another post
im sure someone can answer you better than me, but, here i go 1- where his right hand is, you just want to squeez the spring a little bit (so its not loose)(and you dant want to change the spring load by lowering or raising the suspension) 2- you install the coilover, notice that they are not the same height as the stock one ( for the height, i just guested it and adjust after) ![]() 3- make sure that both front are the same height (rear too) ![]() 4- put your mags on and put your car on the floor (the more even the floor is the bether it is) 5- mesure how much you want to raise it or lower it 6- when you want to change the ride height, you dont need to desassamble the hub and every thing you just need to get your wheel off 7- first thing you want to do is loosen the bottom ring (a lot)(raise her a inch or two) ![]() 8- if you want to lower it, take the 'key', put it on the top ring and 'unscrew' it (the tread will 'enter' in the hub and this will lower the car) (when you work with the top two ring, you always want them to work against the other one, since you dont want to change the load on the spring) (you will understand this part when you will do it ![]() 9- if you want to raise it, take the 'bottom top ring' and 'screw it' ![]() 10- thighten the bottom ring and make sure that both front are the same height (and both rear) 11- put your wheels back and if it sit the height you want....... ....... LOWER IT MORE 12- ANJOY P.S. i am no professionnal and this is what i learned by my self (im sure the're might have thing i could of do better) -------------------- ![]() |
Mar 19, 2010 - 12:48 AM
man...i swear i searched the forum...a GOOD 35 minutes and gave up...i click everything post....thanks for the future reference....what i did was just measure both struts at the same height....(on level floor), balance the pillow mounts so they are on straight....measure the gaps (the open space "thread" part) to make sure all equal with a tape measure. Put it in and start adjusting the two rings holding the spring in tight...my only problem was having the fronts lowered too much....it push ALL THE WAY to .5" funny is that it didn't scrap but the tires were rubbing, adjust it to 1.25" in the fronts and same things for the rear, but with height at 2" approximately. I F*CK up the washers on the top of spring with the two fronts because the springs were to low and it came out of place, but i just simply fixed that by adjusting the springs back up to fix the bent washers as best as i could...hopefully this won't be a problem...
I'll post pictures tomorrow when i get back from work. i spilled most of the oil fluid by accident and manage to only lubricate the two rear...i need some more for the fronts---->> anyone know where i can buy some more, can i just use some grease or it has to be that thin oil fluid? BEFORE pic with REAR: ![]() ![]() DON't have the fronts before....these are the after shots. Front tire ![]() REAR tire ![]() How it sits to the ground ![]() ![]() Rear tire ![]() Front tire ![]() ![]()
This post has been edited by chacha: Mar 20, 2010 - 7:49 PM |
Mar 19, 2010 - 12:55 AM
great news is that i got these BRAND NEW for $810 shipped straight from ksport warehouse in AZ. two 2-3 weeks
Mar 19, 2010 - 7:49 PM
all done...that's how it sits for now...waiting for cusco lower arm bar and under brace body bar.
1.1 in all around This post has been edited by chacha: Mar 20, 2010 - 7:50 PM |
Mar 22, 2010 - 8:53 PM
does anyone know if camber kits are necessary for coilovers?
Mar 22, 2010 - 9:01 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Only if your camber is out of spec. Judging from your pics, it is not.
Is that 1.1 how much you dropped in inches? No way that's true, I dropped slightly less than you and my Sportline springs are rated at 1.5". However, I never really measured. Either way, congratulations. Looks great. This post has been edited by SwissFerdi: Mar 22, 2010 - 9:01 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Mar 22, 2010 - 9:33 PM
those pics don't tell much...as you can tell, im really a noob on this subject....i found that these ksport offer adjustable camber kit on the pillow mount...my question should have been how do i adjust them correctly? how do i know good is good from bad?
Mar 22, 2010 - 9:46 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
those pics don't tell much...as you can tell, im really a noob on this subject....i found that these ksport offer adjustable camber kit on the pillow mount...my question should have been how do i adjust them correctly? how do i know good is good from bad? in reality you need to go to a shop and get an alignment... camber is not the only measurement you need to be concerned about... -------------------- |
Mar 22, 2010 - 10:23 PM
thanks...im planning to take it to a shop to get an alignment, but i don't want them to charge me for adjusting the camber so my tires don't butterfly out....and as of now, the tires, bottom portion sticks out more than the top half....figure i do the adjusting on the cambers myself with the 6gc family's help.
Mar 22, 2010 - 10:28 PM
No, you need to get a camber kit. Search for the one from Eibach on Tire Rack, I've heard good things about that kit.
Here, I did it for you. http://www.tirerack.com/suspension/suspens...artnum=5.81260K This post has been edited by SwissFerdi: Mar 22, 2010 - 10:29 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
Mar 23, 2010 - 6:34 AM
thanks swiss...ill check them out
Mar 23, 2010 - 10:42 AM
I thought the whole idea of the ksports were that they allow for camber adjustment?
Mar 23, 2010 - 11:05 AM
I thought the whole idea of the ksports were that they allow for camber adjustment? they do! all full coilover systems have the top mount. you can also adjust at the knuckle, like a regular mcpherson strut set up. you need to take it to get aligned tho... sai, caster, toe are all factors to look at. -------------------- |
| Lo-Fi Version | Time is now: September 15th, 2026 - 1:41 AM |
