Mar 23, 2010 - 7:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
about 2 cups of coolant is disappearing every 200 miles from the radiator.
I have a brand new radiator that came with a new cap, i put new hoses. The overflow reservoir is remaining at the same level always. There are no leaks and no coolant is in the oil. . . . Where is it going and if it is just "using" it, why is it not sucking back the missing from the reservoir? Bad radiator cap? Something else? Any help appreciated... -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Mar 23, 2010 - 8:57 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
internal leak??
-------------------- God made man....
Everything else... Made in China ![]() |
Mar 24, 2010 - 11:03 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
throw some of the uv dye in the coolant and go from there...do a pressure test on the coolant system...see if it holds pressure
This post has been edited by rjbibeau: Mar 24, 2010 - 11:05 AM -------------------- ![]() |
Mar 24, 2010 - 1:43 PM
internal leak?? Aren't there only two places it can go? The oil or the combustion chamber? Its not in the oil and it is not burning it from what i can tall... throw some of the uv dye in the coolant and go from there...do a pressure test on the coolant system...see if it holds pressure I might try that next..... I tried to change the radiator cap today but it seems the radiator is a non standard size and other caps besides what came with it wont fit. I also bled all the air out of the system today. -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Mar 24, 2010 - 5:44 PM
i had internal leak before, my cylinder head has cracks but i never saw coolant mix with oil but the other way around. my radiator started to become muddy and i was loosing coolant and overheating.
Mar 24, 2010 - 7:49 PM
Enthusiast ![]() ![]() ![]() Joined May 22, '08 From dallas texas Currently Offline Reputation: 11 (100%) |
i had a hairline crack where the round part for the cap meets the top plastic piece...it was hissing out and burning off before it hit the ground, i could smell it but couldn't see it...check those areas (top and bottom) for tiny cracks. if it just bubbles out it can burn off before it hits the ground
Apr 1, 2010 - 6:51 PM
i had a hairline crack where the round part for the cap meets the top plastic piece...it was hissing out and burning off before it hit the ground, i could smell it but couldn't see it...check those areas (top and bottom) for tiny cracks. if it just bubbles out it can burn off before it hits the ground its a brand new all metal radiator. UPDATE: ok so i've been topping off the radiator for a while now, and no changes to the system have been done. The reservoir has remained at the "full" level each time i've filled the radiator. BUT yesterday, all of a sudden when i shut the car off, ALL the extra coolant I've been putting goes into the reservoir and then onto the floor when it filled up. Where does it disappear to and why did come back with such a vengeance, and instead of gradually fill the overflow just dump it all at once? -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Apr 1, 2010 - 11:18 PM
is the tube from the radiator to the overflow clogged?
Apr 2, 2010 - 12:34 AM
is the tube from the radiator to the overflow clogged? nope it surely is not. I just put a new hose there actually.... -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Apr 2, 2010 - 7:26 AM
is the system building pressure normally?
Apr 2, 2010 - 12:43 PM
is the system building pressure normally? it seems so, If i remove the radiator cap when hot it definitely releases the pressure... -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Apr 2, 2010 - 7:30 PM
how fast does it build pressure when you start it from cold? how does the coolant smell? is there any 'scum' ontop of the coolant?
Apr 2, 2010 - 7:43 PM
how fast does it build pressure when you start it from cold? how does the coolant smell? is there any 'scum' ontop of the coolant? from just leaving the car on idle until it reaches temperature it will take 15-20 min. While driving it, it seems to build pressure in about... 10-15 min, or about 10-15 miles of driving. no the coolant is clean, if you are implying that oil might be getting in, or vice versa, no. Both the oil and the coolant are clean and have no traces of each other mixing. i swear i have the strangest issues.. lol. This post has been edited by samir0189: Apr 2, 2010 - 7:44 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Apr 2, 2010 - 7:52 PM
you don't have to have oil mix to have a head gasket issue.
Apr 2, 2010 - 10:34 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
stupid question but you did mix half coolant and half water didnt you
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Apr 3, 2010 - 12:06 AM
you don't have to have oil mix to have a head gasket issue. ok i did not know that, didn't mean to sound smart if thats how it came across.... i appreciate all the help bitter. i was always under the impression it would mix if the head gasket was the cause.. what could be the problem? stupid question but you did mix half coolant and half water didnt you yessir i keep it 50/50, or as close as possible. -------------------- ◊◊◊ My F/S Thread! ◊◊◊
May 4, 2010 - 12:54 AM
I guess it seems fixed for now, i changed the thermostat, the temperature had been going from half to "too hot" within seconds so i figured it was worth the change...... so far the car gets to operating temp alot quicker, and no more overheating or loss of coolant.
May 4, 2010 - 7:38 AM
Enthusiast ![]() Joined Apr 28, '10 From Ft Worth Currently Offline Reputation: 0 (0%) |
Mine was leaking from the head gasket. very slowly but thats where I found it to be going. Never did get into the oil at all though. Chaging out the head as we speak!
May 4, 2010 - 1:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
To the next 280k, eh? -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
| Lo-Fi Version | Time is now: September 13th, 2026 - 5:41 AM |
