Mar 25, 2010 - 4:47 PM
I got hold of some beams axles recently, and im changing the boots, but they old grease is messed up,
I cannot even think to realize how to take the outer joint apart, i have cleaned it with brake fluid, but i believe its not good enough and i don't want to leave residue. After intense hours of reading and googling, finally found the answer. Beams axles are different than our celicas, our inner joint in the celicas are scalloped, which means that its a system of 3 bearings systems, compared to 6 bearing balls in the beams which is the same as any 3sge axles, which may explain the increase in strength for HP. the inner joint for both sides and inclusive the intermediate shaft are shared with the celica 86 gts. Re moving the boots are easy, just some clips and they are loose, then is the grease mess. 5sfe with 3 bearings on a hub ![]() 3sge with 6 ball bearings ![]() The inner axle joint is disassembled by removing the retaining clip. then there is ring pin to remove the hub in both axles. make sure you mark were everything goes. the outer cv joint is the most difficult. tap it hard with a mallet hammer to take it out it has an inner retainer clip just like the clip in the tranny, it takes a good blow to take it out ![]() to clean the inner joint disassemble the bearings first, then the hub then the cage.. ![]() ![]() reversal is the installation procedure, i dont have my own pics at the time, im using net pics, but i will post some later. cheers. I will post pics of the beams axles, procedure is the same. The shafts are actually thicker than the 5sfe. This post has been edited by njccmd2002: Mar 28, 2010 - 9:18 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Aug 8, 2011 - 10:18 AM
Enthusiast ![]() Joined Oct 16, '09 From Norway Currently Offline Reputation: 0 (0%) |
Do anyone have the parts number for the circlip on the 3sge outer joint? Mine is missing!
Aug 8, 2011 - 12:09 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
This shoudl be stickied.
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 27, 2011 - 6:46 AM
Enthusiast ![]() Joined Jun 28, '07 Currently Offline Reputation: 0 (0%) |
If the axles are knocking only during full-lock turning (low speed, quick acceleration), is it probably/definitely too late for just a cleaning and repacking? Guess a cleaning and re-lubrication will most likely make it last longer, either way...
Thanks |
Aug 27, 2011 - 1:13 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
That would depend on the amount of scoring on the race/cage/bearings.....if its something you can catch early on, then a rebuild would be a cheaper alternative.
| Lo-Fi Version | Time is now: September 8th, 2026 - 3:03 PM |
