> Shifting problems
post Mar 27, 2010 - 3:25 PM
Ted95
Joined Mar 8, '09
From Westport, MA
hey guys todays my s54 tranny has been givin me trouble shifting and im not sure why. i drove to my uncles next door and everythin was fine, the car sat for 30min or so then when i went to leave the car would not go into gear. i pushed pretty hard on the shifter and had to force it into first and eventually second and it hesitated into 3rd ( i didnt do 4th or 5th bc it was only 3 houses over) then down shifting was rough too. once i had the car back in the driveway i had the car running and tried and put it in gear and nada, it wouldnt go in unless i forced it really hard which i didnt want to do. i shut the car off and it went thru all 5 gears and reverse with no problem. try and start it up again and it wont go into gear.
now i let the car sit for about 15min then started it back up and everything was fine again. then a lil while later i went to pick up my brother and the whole drive thru town it was hesitating to go into eqch gear and had to to it forcefully kinda. (is that classified as slipping?) i mean it doesnt slip out of gear so i dont think the clutch is messed up, its my first 5spd and i havent had to replace the clutch yet, so wat does it sound like to you guys?
st205 powered ss3 coupe
post Mar 27, 2010 - 3:46 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
Try checking your shift cables?
post Mar 27, 2010 - 8:08 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (cyberblader1130 @ Mar 27, 2010 - 4:46 PM) *
im going to tomorrow my friend suggested it
post Mar 29, 2010 - 11:00 PM
BoostedGT
Joined Mar 28, '10
From NY
clutch maybe..
post Mar 30, 2010 - 2:30 AM
fgvillegas
Joined Mar 22, '10
From Philippines
That happened once to me and the pressure plate was the culprit.
The thing is, I have done the following one by one before it was finally detected:
- Replaced clutch master and clutch fluid. Secondary clutch was ok so nothing was done on it
- Replaced transmission oil
- Checked shifter cables
Maybe you could try the above first before going into the clutch.
Worst case, it could be the synchros. But if you don't have any grinding sound when you shift, then it could be another thing.
Shifting problems are really annoying. Please keep us posted.
post Apr 27, 2010 - 2:56 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Any updates? I've been having similar problems...
Lo-Fi Version Time is now: September 20th, 2026 - 1:12 AM
