Apr 2, 2010 - 3:56 PM
Enthusiast Joined Apr 2, '10 From cambridgeshire Currently Offline Reputation: 0 (0%) |
hi can anyone point me in the right direction ive got a 93 celica gt4 st185 rc i cant get any power to the charge cooler pump allready bridged out the leval swich in the cooler and ive test the pump works ok with a seperate power supply but the car is in limp home mode runs but wont rev up properly
Apr 2, 2010 - 4:38 PM
Enthusiast ![]() Joined Sep 14, '09 Currently Offline Reputation: 1 (100%) |
hi can anyone point me in the right direction ive got a 93 celica gt4 st185 rc i cant get any power to the charge cooler pump allready bridged out the leval swich in the cooler and ive test the pump works ok with a seperate power supply but the car is in limp home mode runs but wont rev up properly not sure how similar the setup is between your car and the 205 but i'm assuming you can't scan for fault codes. The pump circut should run through a fuse check the fuses in car and under the hood. One may be blown. If that reveals nothing try to borrow another ECU if you can get one from an RC185. If that works it should save you hours of ugly trouble shooting. Other than that you may have to pull the car battery and run through the harness with a multimeter continuity tester to try to work out what's going on. |
| Lo-Fi Version | Time is now: July 28th, 2026 - 7:51 AM |
