> FS: H.I.D. kit for Celica with warranty, two week sale! reduced price's!
post Apr 13, 2010 - 1:47 PM
ajmorris1977
Joined Jul 13, '09
so a guy here locally is selling H.I.D. kits, i have bought both high and lows or my cars and i'm very happy so i'm buying a bunch to sell on here,
brand new HID conversion kit. This Kit is mannufacturered under strict quality control and the factory is ISO-9001 certified. The ballast and the burner in this kit have passed the most stringest OEM specific test by Toyota (Denso) of Japan, and they uses these ballast for the OE market in the Southern Americas region and some of the southern Asia countries.
100% water proof construction, you can submerge the entire kit under water and it will function correctly
Integrated one piece Ballast, simplified wiring which eliminates any unnecessary confusion during install.
0.3% failure rate, compared to 5-10% failure rate of other HID Conversion kits currently out on the market, the reliability is comparable to that of OEM HIDs
Color temperature output has tolerance of +/- 100K, the tolerance is unnoticeable by human eyes
Superior lumen output compare to its competitor
Best quality burners from Bosch Japan
Choose from 5 different color temperature, you will indefinitely find the color out put of your choices
this is the kit you will recieve...
2 x Ballasts
2 Xenon Bulbs
10 Zip ties
2 Heavy duty heat resistant double sided self-adhesive pads
2 Connector
Manual
Warranty Card (Required for warranty replacement)
Power consumption: 35watts
Voltage: 85V +/- 17V
Luminous flux: 2800
Service Life: up to 3000hrs
Input Voltage: 9V-16V
Working current (Steady state): 3.5 A nom
Ignition voltage: 24kV Peak Max, 18kV Peak Min
Lamp Frequency: 450 Hz
The ballast and the bulbs will come with two year warranty under normal use. Warranty will cover all normal defects, any physical damages will void the warranty
the price for the kits is $65 shipped within the U.S.A. and $120 Shipped for the both sets (high and low) within the U.S.A.
I can ship to anywhere but shipping charges will go up for international.
thanks for reading the ad, if you wish to order PM me with the temperature you want and weather you want high, low or both kits, payment to
puppy.magda@gmail.com
some f.a.q. answers....
Q. Can't I just purchase a stronger watt halogen bulb to get a brighter light?
A. XENON H.I.D. lamps are 35 watts while traditional halogen bulbs are 55 watts. Even though XENON H.I.D. lamps draw less wattage and current, they produce 3 times more light than its counter part, halogen bulbs. Lower wattage does not mean less light output, Xenon are much more efficient, in another word, more power is being put in to more functional use, similar to a smaller liter engine are capabile of producting more power than bigger engine with more liter because it is more efficient. Increasing the wattage will make the bulb a little brighter however it will create excess heat and it will damage your housing and harness. Also, AMPS = WATT(55watts in most cases)/ BATTERY VOLTAGE OUTPUT (12V). So as you increase the wattage on your bulb you increase the current draw on your entire electrical system. This is critical in motorcycle applications.
Q. Can I Install the kit myself?
A. For anyone who is mechanically inclined, this installation is considered "do-it-yourself". While a typical installation takes approximately an hour and some application can even be installed in 20 min, it can vary depending on application (conversion or auxiliary). Our kits are ready to install right-out-of-the-box and come complete with everything that you will need. We also provide you a full set of easy-to-read, step-by-step instructions to guide you.
Q. What is the difference between genuine XENON HID lights and Xenon gas-filled bulbs?
A. High Intensity Discharge (H.I.D.) is a type of lighting technology that replaces the filament of the light bulb with Xenon gas. The gas is ignited to produce an arc of light, when high voltage is applied. The amount of light output is three times that of a standard halogen bulb. The lamps also glow at a higher light temperature (closer to natural sunlight) that gives it its distinct color and appearance, and on the other hand, the Xenon gas filled bulbs are still traditional filamented bulbs, however they replace the halogen gas with xenon gas so it appears whiter and last abit longer when its operating at higher wattege .
Q. Could I re-install the original halogen bulbs after the XENON H.I.D. kit has been installed?
A. With the growing popularity of leasing vehicles, a big concern is whether or not you can bring the vehicle back to its original factory condition. Our kits install with little or no modifications to your vehicle. If need be, the entire kit can be removed and the original halogen bulbs replaced. This kit can be re-installed into another vehicle that uses the same bulb size, therefore, the install is 100% reversable.
Q. What about the quality of your product?
A. The are extensive technology being put in to the making of these ballasts and bulbs, thanks to the effort of many Hella engineers for the ballast and Philips engineers. These kits are trusted by OEM dealer and they installed these kit in their car and seller it for thousands more, and now you can get the same quality kit at fraction of that price.
Q. Why can't replace the halogen bulb in my vehicle with XENON HID lamps with out having to purchase the entire kit?
A. Motorcycles and automobiles currently use a 12 Volt electrical system for their headlamps. XENON HID lighting systems require over 20,000 volts to ignite the bulbs. Once lit, they only require 85 volts to keep running. Our kits include a power pack that is necessary for the lamps to turn on. The input of the power pack is 9-16 volts. It is an integral part of the system. You DO NOT require any additional components to install the xenon HID lamp into the original socket of the halogen bulb.
Q. What's the warrenty period for these HID kits?
A. The ballasts and bulbs come with 24 months warranty from all factory defects. If any component fails within warranty period, we will replace the defective component immediately. Contact us with a description of the problem and we will be happy to assist.
This post has been edited by ajmorris1977: Apr 24, 2010 - 11:11 AM
You're here for a good time, not a long time. - Colin McRae
When in doubt... Flat out! - Colin McRae
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you....
post Apr 13, 2010 - 10:24 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
i personally would tell you too not sell them..
xentec's have a bad failure rate i know because i went threw them.
i just don't wanna see you dealing with returns and faulty ballast but its up too you..
i might be completely off and this might be a excellent shipment of them just don't wanna see you be flooded with problems...
feel free to delete this if i crossed any rules im sorry if i did
This post has been edited by terbear4god4life: Apr 13, 2010 - 10:27 PM
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post Apr 13, 2010 - 10:59 PM
ajmorris1977
Joined Jul 13, '09
QUOTE (terbear4god4life @ Apr 13, 2010 - 11:24 PM) *
well this guy does offer a warrenty so i'm not worried too much, plus i'm running them in my own cars and my friends at the local car clubs cars and we have not had any issues, thanks for the input but I don't forsee any problems. anyone interested can do their research and see if what you say is common but i have never heard it from anyone but yourself, and i did some resaerch after you commented on my last sale thread.
post Apr 14, 2010 - 2:25 AM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
alright sweet its all good just wish my seller i bought from actually respected warranty's
post Apr 14, 2010 - 7:50 AM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
dam you should have had this before cause Ive been wanting yellows...Oh well, cant wait for the others to get here!!!
post Apr 17, 2010 - 11:27 AM
ajmorris1977
Joined Jul 13, '09
bump
post Apr 17, 2010 - 11:44 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
how long u gonna have these?
post Apr 17, 2010 - 11:47 AM
ajmorris1977
Joined Jul 13, '09
QUOTE (stephen_lee @ Apr 17, 2010 - 11:44 AM) *
indefinatly, its no problem getting them whenever...
post Apr 17, 2010 - 12:23 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
badass ill hit u up when i get paid next, end of month
QUOTE (ajmorris1977 @ Apr 17, 2010 - 11:47 AM) *
post Apr 20, 2010 - 1:52 AM
ajmorris1977
Joined Jul 13, '09
QUOTE (stephen_lee @ Apr 17, 2010 - 1:23 PM) *
no problem just let me know...
post Apr 22, 2010 - 3:48 PM
ajmorris1977
Joined Jul 13, '09
bump to the top!
post Apr 25, 2010 - 12:40 AM
ajmorris1977
Joined Jul 13, '09
bump
post Apr 25, 2010 - 10:44 PM
ajmorris1977
Joined Jul 13, '09
i have them on my car, look here for pics of the lit up....
here is a standard light pattern....
here is the hid (6000k) light pattern...
This post has been edited by ajmorris1977: Apr 25, 2010 - 11:32 PM
post Apr 27, 2010 - 9:36 PM
ajmorris1977
Joined Jul 13, '09
bump
post May 1, 2010 - 1:13 PM
ajmorris1977
Joined Jul 13, '09
QUOTE (ajmorris1977 @ Apr 27, 2010 - 10:36 PM) *
bump
again, up!!!
post May 3, 2010 - 2:07 PM
ajmorris1977
Joined Jul 13, '09
bump
Lo-Fi Version Time is now: August 20th, 2026 - 5:29 AM
