Apr 13, 2010 - 11:21 PM
Enthusiast ![]() Joined Mar 26, '09 From Colorado Springs Currently Offline Reputation: 0 (0%) |
http://cgi.ebay.com/ebaymotors/1995-Toyota...sQ5fAccessories
check these out and see if they are worth the money or if they seem cheezy to you guys haha i need some imput please |
Apr 13, 2010 - 11:47 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
idK? i wouldn't go drilled AND slotted. especially with ebay discs. I've heard of them cracking.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Apr 14, 2010 - 12:19 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
If you must get slotted or drilled rotors power slot makes slotted rotors for the ST Celicas here's a link for an example as you can see it's almost $90 each and much safer then the ebay ones.
http://www.coolcarpartsonline.com/power-sl...otor-front-left -------------------- "To Protect And To Serve The Wealthy" -POLICE
Apr 14, 2010 - 12:58 AM
okay sweet thanks haha thats why im on here
just i kinda like the look of the drilled and slotted rotors so ya but i mean are they really even going to help performance wise? im thinking not but its ok just in it for the looks haha not going to lie but i deff wouldnt want to buy something that would crack on me so thanks |
Apr 14, 2010 - 3:55 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
Drilled rotors are to get gasses produced under hard braking away from the pad-rotor contact surface. Modern materials don't offgas. As a result, holes in your rotor are decorative at best. Drilled holes (as opposed to Porsche's rotors where the metal is cast with the holes already there) promote fracturing.
Slotted rotors are meant to clean glazing off of brake pads, due to the pad effectively melting at high heat. Modern, use-appropriate pads do not glaze (well, you might manage to glaze a street pad while you're running in auto-cross, but that's a demonstration of stupidity rather than product failure). Slotting also reduces the rotor's structural strength, though not nearly to the same extent as drilling holes. It should also be noted that as a general rule the increase in surface area (dissipation) is outweighed by the loss of mass (absorption). Very detailed explanation: http://www.celicatech.com/forums/showthread.php?t=1646 |
| Lo-Fi Version | Time is now: March 21st, 2026 - 7:56 AM |
