Jun 11, 2013 - 8:19 AM
Enthusiast ![]() ![]() Joined Nov 29, '07 From Colorado Currently Offline Reputation: 4 (100%) |
Got the head off of the BEAMS. And finished extending the wire harness! Pictures or it never happened. I'll get pictures up in my build thread later. Finishing up the harness today. Going to finish scraping all of the old gaskets away today if I can. The engine is going in this weekend. In a very strange manner, unless I'm completely blind, I haven't found the OCV filter... The only thing that was in the VVTi galley was just the sensor itself.... -------------------- 2019 M2, 2005 S2000, 1997 4Runne
Jun 11, 2013 - 10:56 AM
The OCV filter is hidden inside the head. There's a piece that comes off of the top of the cams, it's inside that.
Jun 11, 2013 - 12:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 Currently Offline Reputation: 53 (100%) |
Today I rolled my fenders.
Jun 11, 2013 - 4:07 PM
The OCV filter is hidden inside the head. There's a piece that comes off of the top of the cams, it's inside that. ![]() Ah, thanks! Never would have noticed it. I thought that was just a black washer of sorts. -------------------- 2019 M2, 2005 S2000, 1997 4Runne
Jun 11, 2013 - 4:08 PM
Nope, it's the worst place for an OCV filter known to mankind. I haven't made it that far into my BEAMS yet. It's such a pain for a $3 part.
Jun 11, 2013 - 7:20 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
Got my tyre put back on...remounting it now.
Also got this in the mail: ![]() And another to pick up this afternoon!!!! -------------------- |
Jun 11, 2013 - 7:37 PM
have knee surgery, and be done with it. Swap your celi to an auto tranny. really, if you are having knee problems, the last thing u need is a crampy car. You need easy ingress and egress out of a vehicle. and auto transmission. you need a automatic echo. small, reliable, and old folks liked it because it was easy to get in and out. I'd be afraid to have knee surgery. I know a lot of people that've had back, neck, and hip procedures only to end up worse than before the surgery. I'm only 5' 10" so the Celica isn't really that cramped for me. Main issue is having to operate the clutch without driving it like a jackass, that and not having the smoothest of rides. Getting in and out does hurt at times, but just while I'm doing it and I'm fine once in or out. Is it just me or does the Celica have an abnormally stiff clutch? The clutch in my brother's V6 Maxima is lighter, and so is the clutch in my uncle's 5S-FE MR2. This kind of befuddles me. Anyhow I'd kill myself if I had to drive an automatic Echo, you think I complain now. This post has been edited by Box: Jun 11, 2013 - 7:37 PM -------------------- 2001 Miata LS 5-speed
Jun 11, 2013 - 8:21 PM
Just snapped a wheel stud...awesome
Jun 11, 2013 - 8:26 PM
Just snapped a wheel stud...awesome Oh, that won't be any fun... -------------------- 2001 Miata LS 5-speed
Jun 11, 2013 - 8:47 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Jun 11, 2013 - 8:59 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) |
Amongst exams, JDM Rain Guards arrived.... Only to have slight damage in post (from poor packaging, so unlikely EMS will cover), and the kicker is that I think they must be off the 7th gen, as they don't follow the lines of the car properly.
Can anybody confirm if the embossed Toyota stamp in the plastic should be at the top over the window, or the bottom near the door mirror? And here's me thinking paying eBay premiums on items would make it less painful... Seller is jdm_used_parts. I would avoid purchasing from this seller for the mean time if possible - as far as I can currently tell the item was not the set pictured, was not in the condition described, were not packaged well enough and were damaged in transit. So far the seller has not been very helpful and has denied everything and has told me to take up the matter with my local post office. This post has been edited by JoshuaM: Jun 11, 2013 - 9:04 PM -------------------- ![]() SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
Jun 11, 2013 - 9:19 PM
Enthusiast ![]() ![]() ![]() Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
Just snapped a wheel stud...awesome Mine snapped with the wheel on one time. Magically 2 studs had fallen off (possibly my fault...possibly not), and being as they weren't all diagonal from each other too much pressure got on one and it snapped. I was driving down the road and next thing I know my wheel is wobbling, scared the piss outta me. Its an easy change though. Just take the wheel off, move off the whole caliper assembly and rotate the stud hole you need to replace with the hole in the caliper shield. Knock old one out w/ screw driver and hammer. Take the new one and push it as far as you can by hand. Thennnn take a 1/2" washer and put it behind a lug nut and gently tighten it all the way down whilst keeping pressure on the back of the stud. Finally put everything back on and bam your done You pbly knew all that but I wanted to show off my e-peen Lower nut on the coolant neck stripped... [img]http://i1151.photobucket.com/albums/o635/Ask92/2013-06-11131238_zpsb8d14113.jpg[img] You dun goofed. No but really, those nuts on the water pump outlet neck are freaking stupid small and weak. The neck itself is some great quality dirty cast aluminum, but the nuts are ridiculously ****ty. You got a grab-it? Should be able to get it out in no time with one. Today I washed my seats, carpet, and mats. They all for the most part all look brand spanking new almost 20 years later. Love it. This post has been edited by travisxcore: Jun 11, 2013 - 9:25 PM |
Jun 11, 2013 - 9:31 PM
You has Celica again? -------------------- 2001 Miata LS 5-speed
Jun 11, 2013 - 10:01 PM
It's handy to read all that again.. I did try that when I replaced them but it was way too much effort tightening it, so I just used a rattle gun. So waiting till I get my hands on that again
Jun 11, 2013 - 10:17 PM
Your supposed to use a rattle gun, that's what makes it an easy quick job
Jun 12, 2013 - 10:09 PM
Today I checked out my uncle's 2000 supercharged Miata. They're very nice cars. All I could do was sit in it and get a general feel for the car though, he has it torn down and is refurbishing the supercharger. The clutch reminded me of the Celica, firm and even throughout travel. The seats were very comfortable, getting in and out of it felt like it does with the Celica though. The amount of room for front passengers feels the same as what the Celica offers. Being 5' 10" I have plenty of headroom and legroom. High quality materials throughout the interior, reminded me of the Celica in that regard as well. To me it's almost like a RWD Celica convertible where they cut out the useless rear seat.
This post has been edited by Box: Jun 12, 2013 - 10:13 PM -------------------- 2001 Miata LS 5-speed
Jun 13, 2013 - 7:55 AM
I just got reminded that I should probably get new radiator hoses.
Also, finished the wire harness. Still working on prepping the head and block to put it back together. -------------------- 2019 M2, 2005 S2000, 1997 4Runne
Jun 13, 2013 - 1:01 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Finally bit the bullet and got the celi tinted. Just couldnt take another Texas summer again without it. Don't know why I didnt do this earlier!
Jun 13, 2013 - 4:22 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
am going out in this monsoon and wetsanding my bumper!!! (might as well! its raining sideways!!)
Jun 13, 2013 - 8:21 PM
Today I joined the miata.net forum.
| Lo-Fi Version | Time is now: September 7th, 2026 - 8:16 PM |
