Apr 22, 2010 - 10:26 PM
Enthusiast ![]() Joined Dec 30, '09 From houston Currently Offline Reputation: 0 (0%) |
ok i tried lowerin my car twice first i used some eibachlowering springs and for some reason they would get compressed too much and they would literely hit each other on every bump and now i bought some coilovers from ebay and they do da same thing but worse im wondering is it that im usin da wromg type of stuff or is that just normal help me out ppl?
Apr 22, 2010 - 11:30 PM
![]() Enthusiast ![]() Joined Apr 20, '10 From Fremont, Ne Currently Offline Reputation: 0 (0%) |
Try Megan racing springs... i believe they are 1.75 rear and 1.5 front. check my pic on my profile page and you will see how they sit with 17 inch wheels and 45 series tires. maybe you need new struts? just a thought
Good luck AuffyZ |
Apr 23, 2010 - 8:21 PM
where can i find da lowering struts if thats wat theyre called?
Apr 23, 2010 - 8:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
Apr 23, 2010 - 10:51 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 22, '04 From FL Currently Offline Reputation: 1 (100%) |
It might be a good idea to ask this question WITH PROPER spelling and grammar in suspension forum.
-------------------- Captain Pessimist
Apr 23, 2010 - 11:02 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
ok i tried lowerin my car twice first i used some eibachlowering springs and for some reason they would get compressed too much and they would literely hit each other on every bump and now i bought some coilovers from ebay and they do da same thing but worse im wondering is it that im usin da wromg type of stuff or is that just normal help me out ppl? what would hit each other? -------------------- Breaking Axles...
Apr 24, 2010 - 7:38 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
ok i tried lowerin my car twice first i used some eibachlowering springs and for some reason they would get compressed too much and they would literely hit each other on every bump and now i bought some coilovers from ebay and they do da same thing but worse im wondering is it that im usin da wromg type of stuff or is that just normal help me out ppl? what would hit each other? I'm guessing he's saying that the springs were so compressed in one area they would hit each other on bumps. -------------------- Has no more Celicas
Apr 24, 2010 - 7:49 AM
if your having a problem with eibach springs, its more than likely a shock, or other problem.
springs almost never fail. eibach also has a 1 million mile warranty. i've had mine for i dunno, 6 or 7 years with no problems. -------------------- Former Team 5SFTE pro member ;)
Apr 24, 2010 - 7:53 AM
if your having a problem with eibach springs, its more than likely a shock, or other problem. springs almost never fail. eibach also has a 1 million mile warranty. i've had mine for i dunno, 6 or 7 years with no problems. Wouldn't installing the spring upside down cause it to compress like he's describing? This post has been edited by Keiri: Apr 24, 2010 - 7:53 AM -------------------- Has no more Celicas
Apr 24, 2010 - 11:09 AM
A spring is a spring, if you flip it upside down it should retain same tensile strength. Only reason for him to have any kind of problem is, like manny pointed out, a blown shock but most likely he installed springs from a different car that is marginally lighter than what celica weighs. I am sure there is a... ohh I dont know a kia or something that weighs 1000lbs less and has similar diameter springs. That would explain why spring would bottom out.
Unless.... He is doing 300ft long jumps in a rally at which point spring would definitely bottom out. In rally they use shock and strut systems that costs thousands of dollars a piece to withstand that kind of abuse. -------------------- Captain Pessimist
Apr 25, 2010 - 11:04 PM
DA SHOCKS WERE BRAND NEW TOO AND IT STILL HIT GOOD THING I GOT DA MONEY BAK...I TRIED TO GET SOME KYB'S AND THEY WERE WAY DIFERENT IT WAS JUST DA STRUT CARTRIDGE
WELL WHEN I BOUGHT THEM I ASKED FOR DA ONESS FOR MY CAR SO IM PRETTY SURE THEYRE DA RIGHT ONES |
Apr 26, 2010 - 9:49 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Your typing is giving me a hernia. Please turn off caps and try for some grammar.
Now, with properly installed springs and struts, this shouldn't be happening. Like others said, the springs aren't to blame - it's the struts. Just know that the cartridges, which are a shock insert, ONLY work for the front, NOT the rear. Maybe you messed up there, as KYB only makes a full strut assembly for the rear. Lastly, what are your driving habits? You didn't mention when the springs compress fully. If you're going over a speed bump at considerable speed, then they could compress like this, although it's still unlikely. This post has been edited by SwissFerdi: Apr 26, 2010 - 9:53 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Apr 26, 2010 - 10:06 AM
Enthusiast ![]() Joined Feb 25, '10 From in A land Far Away Currently Offline Reputation: 0 (0%) |
To true dat bruv, my word what is all that about, get some photo's up of your problem..
Your typing is giving me a hernia. Please turn off caps and try for some grammar. Now, with properly installed springs and struts, this shouldn't be happening. Like others said, the springs aren't to blame - it's the struts. Just know that the cartridges, which are a shock insert, ONLY work for the front, NOT the rear. Maybe you messed up there, as KYB only makes a full strut assembly for the rear. Lastly, what are your driving habits? You didn't mention when the springs compress fully. If you're going over a speed bump at considerable speed, then they could compress like this, although it's still unlikely. |
Apr 26, 2010 - 6:31 PM
i dont have piks but i mean da spring would compress as soon as i would put da car down so any little bump itwould hit and like i said da struts were bran new i put the, on when i bough da springs
Apr 26, 2010 - 7:23 PM
Your typing is giving me a hernia. Please turn off caps and try for some grammar. Now, with properly installed springs and struts, this shouldn't be happening. Like others said, the springs aren't to blame - it's the struts. Just know that the cartridges, which are a shock insert, ONLY work for the front, NOT the rear. Maybe you messed up there, as KYB only makes a full strut assembly for the rear. Lastly, what are your driving habits? You didn't mention when the springs compress fully. If you're going over a speed bump at considerable speed, then they could compress like this, although it's still unlikely. Um Swiss...that's not exactly true as KYB does make front struts that are sealed; I bought 2 as my '99 has Sport Suspension - sealed struts. And it's quite possible what he's saying is true because my Sportlines are compressed like he's describing but I only get clunking on the driver's side which I think I installed incorrectly. I'll know more this weekend when I pull the front driver strut setup and redo it. Also, I bought 4 brand new struts boots and bumpstops, new 4.0782 Sportline spring kit, and new upper and lower seat insulators. The only things I didn't change were my strut mounts. I'll get pictures this weekend too. This post has been edited by Keiri: Apr 26, 2010 - 7:24 PM -------------------- Has no more Celicas
Apr 26, 2010 - 7:25 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
i dont have piks but i mean da spring would compress as soon as i would put da car down so any little bump itwould hit and like i said da struts were bran new i put the, on when i bough da springs After the various requests for some attempt at proper spelling and grammar, I can only conclude you're deliberately trying to annoy the helpful members of this forum. |
Apr 26, 2010 - 7:35 PM
Um Swiss...that's not exactly true as KYB does make front struts that are sealed; I bought 2 as my '99 has Sport Suspension - sealed struts. And it's quite possible what he's saying is true because my Sportlines are compressed like he's describing but I only get clunking on the driver's side which I think I installed incorrectly. I'll know more this weekend when I pull the front driver strut setup and redo it. Also, I bought 4 brand new struts boots and bumpstops, new 4.0782 Sportline spring kit, and new upper and lower seat insulators. The only things I didn't change were my strut mounts. I'll get pictures this weekend too. I mean that KYB only makes inserts for the front, not that they make only inserts for the front...capiche? And I do have the same clunk on the driver's side, let me know what you find. I'm thinking it's the top mount not being aligned correctly, but when I change my wheels I'll check the spring itself for play. This post has been edited by SwissFerdi: Apr 26, 2010 - 7:36 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
Apr 26, 2010 - 7:42 PM
Um Swiss...that's not exactly true as KYB does make front struts that are sealed; I bought 2 as my '99 has Sport Suspension - sealed struts. And it's quite possible what he's saying is true because my Sportlines are compressed like he's describing but I only get clunking on the driver's side which I think I installed incorrectly. I'll know more this weekend when I pull the front driver strut setup and redo it. Also, I bought 4 brand new struts boots and bumpstops, new 4.0782 Sportline spring kit, and new upper and lower seat insulators. The only things I didn't change were my strut mounts. I'll get pictures this weekend too. I mean that KYB only makes inserts for the front, not that they make only inserts for the front...capiche? And I do have the same clunk on the driver's side, let me know what you find. I'm thinking it's the top mount not being aligned correctly, but when I change my wheels I'll check the spring itself for play. Gotcha. I'll let you know what I find out this weekend. -------------------- Has no more Celicas
Apr 26, 2010 - 9:19 PM
clunk = end links or sway bar mounts
Apr 26, 2010 - 10:59 PM
ok ok ok i will type correctly so it won't annoy you. can you help me now?
| Lo-Fi Version | Time is now: August 31st, 2026 - 1:48 PM |
