> Oil leak around timing cover
post Apr 26, 2010 - 3:29 PM
Decalsondemand
Joined Nov 12, '08
From ohio
Hi was just wondering if anyone has changed the seals and gaskets around the timing cover? If so, is there a "HOW TO" I will post a picture in a few minutes so you can see the areas its leaking from..Thanks,Brian
This post has been edited by Decalsondemand: Apr 26, 2010 - 4:39 PM
post Apr 26, 2010 - 3:50 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
camshaft seals
p/n????
11151B SEAL, OIL (FOR CAMSHAFT SETTING)
90311-38046 5SFE..ST204 1 $11.78
post Apr 26, 2010 - 4:27 PM
Decalsondemand
Joined Nov 12, '08
From ohio
will post the pictures in a second there seems to be alot of oil around the coolant neck
post Apr 26, 2010 - 5:19 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
try and check your valve cover bolts. the old members told me to look from top (first) to bottom when it comes to leaks unless you can see the oil building and dripping
post Apr 26, 2010 - 6:19 PM
Decalsondemand
Joined Nov 12, '08
From ohio
they are fine just installed a new gasket and seals
post Apr 26, 2010 - 6:46 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
What is the highest point that is dry?
Because our cars use belts the timing cover is just there to keep dirt out its not really "sealed". The only thing you can do is pull your timing cover off and check.
post Apr 26, 2010 - 8:06 PM
Decalsondemand
Joined Nov 12, '08
From ohio
I would say the lowest point would be 4-5 inches below the valve cover and it is only on the one side of the engine starting by the coolant neck area...so it couldnt be the oil pump or something inside the cover producing the leak?
This post has been edited by Decalsondemand: Apr 26, 2010 - 8:11 PM
Lo-Fi Version Time is now: August 11th, 2026 - 9:52 AM
