> looking for coomers 4age swap thread, already searched
post May 1, 2010 - 12:52 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
so for the past hour i have searched and searched for his thread on swapping the 4age into the st, if anyone could locate a link for me that would be great, and if you plan on being a dick and telling me to search you can post in another thread
2001 Solar yellow Lexus IS300
post May 1, 2010 - 1:43 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Because Coomer doesn't have a swap thread. He had a shop do it.
Here is his renovation thread: http://www.6gc.net/forums/index.php?showtopic=44927
**** Photobucket
post May 5, 2010 - 2:45 PM
pez222
Joined Aug 6, '09
From Tallahassee, FL
This one's more about maintaining and not swapping but I refer to it from time to time. 4AG Info
-ian-
'03 MR-S
'86 MR2
.......... __o
........(_)/(_)
post May 6, 2010 - 7:46 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You need a throttle cable from a 5s Camry and a way to wield on the 4age down pipe to your exhaust system because they don't fit. You will also need a custom hose going from the power steering to your rack and pinion and a custom A/C line to the pump. Don't forget your wiring harness as well. Those are pretty much what you need. Anything else is a direct fit such as the motor mounts and your old axels.
post May 6, 2010 - 10:29 AM
95CelicaST
Joined Feb 5, '05
Paseo throttle cable works as well.
**** Photobucket
post May 6, 2010 - 10:31 AM
QUOTE (soulshadow @ May 6, 2010 - 8:46 AM) *
Not that hard of a swap then...I figure the cost for all of those custom parts is around 500?
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post May 7, 2010 - 8:16 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
QUOTE (SwissFerdi @ May 6, 2010 - 10:31 AM) *
yeah but you gotta replace the old water-pump, timing belt, spark plugs, a full tune up, misc parts here and there and eventually you need around $1000-1500. Toyota quotes 20V pumps at $300 and wire set at $200.
Lo-Fi Version Time is now: September 13th, 2026 - 10:13 AM
