May 7, 2010 - 9:04 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
So about a month ago me and my friend were in an empty parking garage to take pics (city is behind the garage and blah blah). Anyway I noticed my car was making a noise, now noises are hard to explain.
But it sounded like if a belt is a little loose, but not to the loudness extent of a loose belt, just squeak squeak squeak squeak squeak (softly and semi-fast, never noticed it before the empty parking garage where noise is heard very well) So I noticed when I press the clutch in the noise stops completely. The noise is slightly more noticeable now, but only when there are other cars (stuck in traffic) or next to buildings if I listen very carefully. Nothing is wrong with my car, that I can tell. New clutch about a year ago, give or take a few months. Used (70k) 7A-FE not even 6 months ago. Car runs fine, with no other noises. Just wondering if this noise that stops with the clutch being pressed, is sign of something going bad, something bad to come, something I should worry about, or if anyone knows how to fix it. Thanks alot in advance! And feel free to ask any questions This post has been edited by mgnt232: May 7, 2010 - 9:04 AM -------------------- |
May 7, 2010 - 9:59 AM
Enthusiast ![]() ![]() Joined Nov 16, '06 From Findlay,Oh Currently Offline Reputation: -1 (33%) |
its your throw out bearing for your clutch u will be okay for awhile but needs replaced... its just worn out
May 7, 2010 - 10:23 AM
thanks for the answer, but ugh! lol
I am not really sure what that is, do I have to take out the tranni again!? is it also known as the clutch release bearing? thanks alot -------------------- |
May 11, 2010 - 9:07 PM
thanks for the answer, but ugh! lol I am not really sure what that is, do I have to take out the tranni again!? is it also known as the clutch release bearing? thanks alot lol yeah you have to take the transmission out as the bearing is attached to the spline on the tranny not to hard to do but just alot of undoing things ... might as well do a complete clutch job while your in there!!!! and realese bearing and throw out bearing are the same thing |
May 12, 2010 - 6:20 AM
Enthusiast ![]() Joined Mar 22, '10 From Philippines Currently Offline Reputation: 0 (0%) |
One thing you can try before openning your tranny is to spray some wd40 kind of stuff in the area beside the clutch fork. You can open up the rubber portion there before spraying it. My friend encountered the same problem as you and it got solve by doing what I have just told you.
May 12, 2010 - 3:37 PM
that would be awesome! thanks alot, as soon as it stops raining, im going out to try it
May 13, 2010 - 12:55 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
if you are going to do that; don't use wd40 it drys out and can destroy bearings. Use a penetrating oil.
May 13, 2010 - 7:34 PM
like pb blaster? I just used it, and the noise stopped!
May 13, 2010 - 8:52 PM
May 13, 2010 - 9:15 PM
yeah I put anti-seize on the spline, the noise stopped when i sprayed it though, so im happy for now
May 14, 2010 - 6:39 PM
Good to know that the mystery sound is now gone.
| Lo-Fi Version | Time is now: August 26th, 2026 - 6:08 PM |
