May 16, 2010 - 9:15 PM
Enthusiast ![]() Joined May 16, '10 From california Currently Offline Reputation: 1 (100%) |
after pulling the head out of my 3sge
i just decided to do a full race 5sgte engine i got all the parts anyway i decided to do a brake line and hoses tuck on my engine stitchweld and repaint it due to many scratches occured in the past 6 years that i owned it ![]() ![]() removed brake and master cylinder ![]() too many scratches in the engine bay ![]() some parts will be ceramic coated ![]() like this 3s headers rust had occured (nice huh) too bad i wont be using it anymore =( its gonna be for sale later on as a kit ![]() car is bare ![]() Modified by bnicolas at 9:35 PM 3/31/2010 started to cover big holes and weld it later ![]() ![]() started porting my custom intake manifold to accept the ae111 throttle bodies gotta have patience not easy to port no wonder it takes the shop 2 weeks to do it ![]() Modified by bnicolas at 9:35 PM 3/31/2010 what the car used to look like i just need 3 mos to finish it ![]() ![]() ![]() ![]() Modified by bnicolas at 9:36 PM 3/31/2010 engine on stand 2nd gen 3sge hicomp on the left 3sturbo right 5s from a camry ![]() stripping the engine bay ![]() w55 transmission taken down with custom bellhousing and driveshaft ![]() on the way to the machine shop to get oil squirters transferred and water holes done ![]() check out the je pistons oversize ![]() Modified by bnicolas at 6:12 AM 3/11/2010 Modified by bnicolas at 9:36 PM 3/31/2010 just finished covering up the holes ![]() getting ready for painting primer ![]() primered done ![]() Modified by bnicolas at 9:38 PM 3/31/2010 found some uneven spots sanded it again ![]() mixing primer for the last time ![]() final touch ready for paint ![]() i cant finish painting because of the stupid wind Modified by bnicolas at 9:39 PM 3/31/2010 so after 2 shots of clear coat ![]() here you go a clean engine bay money shot ![]() ![]() ![]() will buff it next week Modified by bnicolas at 9:39 PM 3/31/2010 got something done today little by little wire tuck ![]() ![]() installed front end parts ![]() ![]() ![]() Modified by bnicolas at 9:40 PM 3/31/2010 From You!!! lol i would like to pick that beatrush panel but i dont know if my oil pan is gonna be a problem.... while waiting for some parts i decided to reweld the rear fender its too noisy inside ![]() grind some extra welds ![]() and freaking body work again shoot im really getting tired of the shetz ![]() Modified by bnicolas at 9:40 PM 3/31/2010 so can you say lightened crankshaft! just got back from the machine shop and boy they really trimmed this sucker up real good... ![]() hopefully this is good for 10k rpm can you see the difference lightened balance knife edeged what more could you ask for ![]() Modified by bnicolas at 9:41 PM 3/31/2010 got my flywheel resurfaced ![]() past few days went to the junkyard and picked up rx7 fc calipers and borrowed my friends (2tgeu's) brackets so i can fabricate my own francis its all your fault this wasnt in my current plan ha ha naubos tuloy oras ko sa paggawa thanks by the way ![]() anong cad design cayod design the filipino way lol!!!! in english grind in ilokano awan kwarta>>>>> ![]() ![]() painted brake booster and installed master cylinder crossmember and throttle cable ![]() ![]() installed my new celica supra brake calipers ![]() Modified by bnicolas at 7:05 AM 3/24/2010 Modified by bnicolas at 9:41 PM 3/31/2010 my pistons came in today oversize 87.5 for a 5s and no the 87mm oversize mr2 turbo pistons is not going to work due to the pins are high its gonna stick out ![]() ![]() i bought an intercooler spearco 3 1/2 inch thick very nice ![]() had a problem with the center radiator support i have to trim it down ![]() with custom brackets made fits perfect ![]() tomorrow will be upgrading the fuel system for my 1000 cc injectors Modified by bnicolas at 6:53 AM 3/27/2010 Modified by bnicolas at 6:54 AM 3/27/2010 Modified by bnicolas at 9:42 PM 3/31/2010 i know im not even half way done so i drop my fuel tank to add an existing line and to check if its clean i realize that i have another steel line hanging in my engine bay for the the vacuum so i used that instead so i dont have to add another hose again ![]() ![]() here is the hose that i added ![]() so im done putting it back ![]() tomorrow i will be adding another fuel pump so it could feed my 1000cc rc injectors Thank you for the complements Today i drilled holes for my nagisa shock tower plates ![]() ![]() i added another fuel pump ![]() soldered the wires ![]() here is the finishing touch ![]() here you go installed under the car my friend came over i helped him changed brake pads and belts ![]() ![]() Modified by bnicolas at 9:43 PM 3/31/2010 today i swapped my steering wheel from the beast. its been 2 years that i've been slacking ha ha ha too small from chasis ![]() ![]() and here's the 86 ![]() i painted the screws cause its all rusted ![]() im done on the front suspension for now i need to finish the car by next month ![]() ![]() so steering swap is done ![]() feels so good on the beast ![]() ![]() im done with the steering rack ![]() im done with my front end hooked up headlights, foglights signal lights installed my license plate and align the lights it was so hard without the jdm bracket but worked out fine ![]() tomorrow i will be working on my fuel line to install a fpr ![]() Modified by bnicolas at 5:41 AM 3/29/2010 Modified by bnicolas at 9:43 PM 3/31/2010 took this pictures at the machine shop my ported head is done ![]() ![]() ![]() thanks for the refferal Today transmission day Cleaned my transmission with a power washer ![]() Just in case i break this w55 from a 22r I got an extra and 7mgte turbo transmission so no downtime ![]() The secret of the rwd conversion the bellhousing ![]() Transmission installed today ![]() I also replaced the the throw out bearing ![]() and transmission is mounted ![]() I picked up a driveshaft from a 80 toyota corona wagon too long so i have to have it shortened its nice 1 piece woot woot!!! ![]() ![]() ![]() So I started with my own big brake bracket this is Mazda Fc calipers 4 pot right side is stock and 2002 Mini Cooper S rotor ![]() i have to redrill for the rotor to hold ![]() ![]() I will be picking up the the welded bracket at Wellbuilt Kustoms Jimmy's shop in Buena Park Enough today Gotta watch Clash of the Titans with my wife Modified by bnicolas at 1:42 AM 4/7/2010 thats correct Eric 5sfe Block from a 92 camry 2.2 or celica or mr2 na but i dont have a 3sgte its a 3sge non turbo jdm which has bigger ports higher stock cams and springs which is useless cause im going to upgrade today i pick up my home made brackets from wellbuilt kustoms ![]() ![]() the cnc bracket at the bottom borrowed from my friend ![]() Installed it perfectly ![]() and wala im done with my big brake kit for $75 just a little paint here and there ![]() ![]() i also installed my custom brackets made by danstoy with the slave cylinder and exhaust bracket ![]() ha ha hopefully everything works.... today i installed the battery at the trunk its kinda in the middle because i dont want to block the fuel sending unit and its a pain to change tailights ![]() i have an original hks bov that i took apart because this was a kit for the my supra tt i have to get a new flange ![]() Modified by bnicolas at 9:55 PM 4/6/2010 This post has been edited by 3sgelevin: May 16, 2010 - 9:20 PM |
![]() Enthusiast ![]() ![]() Joined Jun 12, '09 From Hull, England Currently Offline Reputation: 0 (0%) |
nice big build thread
May 16, 2010 - 9:18 PM
i know man its cool no one bought it
they never what they could have had and now im to prove them wrong so i painted some of the engine bracket and starter ![]() so my connecting rods came in today now my stroker is complete ![]() crankshaft ![]() pistons ![]() Modified by bnicolas at 1:54 AM 4/10/2010 update april 14th i picked up my 1 piece custom driveshaft today ![]() installed fits perfect and driveshaft is done ![]() ![]() i found a conquest turbo and took the oil cooler from the junkyard its 13 row i decided to use this not the rx7 cause its too long it would be hard to fit it in my levin front end plus its oem the lexus v8 only has 5 row i think ![]() added a fan to cool more ![]() i also put a cushion so it wouldnt vibrate at the back and at the bottom ![]() looks like factory install clean and simple also bought new hoses ![]() ![]() and once again i finished the oil cooler ![]() i made a cover for my shifter so loud inside ![]() too much holes he he so i decided to do a clean one ![]() test fit perfect ![]() painted it ![]() and done ![]() Modified by bnicolas at 7:59 PM 4/14/2010 Modified by bnicolas at 7:59 PM 4/14/2010 no they are not the same im using a custom bracket for my transmission update today april 17th my steel braided lines came in it cost me almost freakin $400 on this lines i could have just gone with copper but its done already ![]() installed on the brake calipers ![]() ![]() i relocated the distributor block hide it somewhere it couldnt be seen ![]() tightened the hoses ![]() ![]() i bypassed the clutch start switch ![]() i made my own jumper wire ![]() and brake lines done ![]() i pulled the wiring harness out the engine bay to be ready ![]() i decided to shortened my custom throttle cable this came off a camry cruise control cable so its still oem and toyota ![]() pulled it out ![]() cut drill etc... ![]() cutting the outer housing ![]() and the inner cable ![]() installing it back ![]() and throttle cable is done ![]() dude dont forget to spread the word for the sds standalone still for sale today i removed my rearend due to my 4.8 gear im not N/A anymore got to make room for spool for my gt35 dbb lol!!! bear in mind that this is brand new gearing with new bearings mann im so tired of this might as well do now than later since my engine is out car is still on jackstands and already upgrading ![]() draining fluids ![]() removing axles ![]() and what do we have here my little parts corner ![]() and look what i have found a 3.9 gear with lsd looks good ![]() and diff is out ![]() and time to go to shop again to have the lsd installed and 3.9 gear installed for the freaking 2nd time ![]() update may1st changing the compressor wheel on my dbb35 ![]() ![]() and its done just got to have it balanced ![]() the secret to oil starvation high volume oil pump some people dont know about ![]() high perfomance valve seals ![]() this is a discountinued 1000cc injectors made by phyton (sidemount) cleaned by rc engineering ready to squirt evenly ha ha ha perfect for my 3rd gen bored out fuel rail by ats ![]() this is an original greddy type r wastegate 50mm ![]() aeromotive fuel pressure regulator ![]() and my oil sandwhich plate ![]() Modified by bnicolas at 4:51 PM 5/2/2010 Modified by bnicolas at 4:52 PM 5/2/2010 Modified by bnicolas at 4:55 PM 5/2/2010 |
May 16, 2010 - 9:30 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
damn
May 17, 2010 - 2:36 AM
yeaaa. pinoy FTW
May 17, 2010 - 12:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
Good job! I love that 86 hatch with that front end... Amazing!
-------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
May 17, 2010 - 4:25 PM
thanks people im resting right now
taking it easy on the build got tired of everyday work on it |
May 17, 2010 - 5:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
thank god you resized the pics.. or else my pc at work would've crashed!
that is a very nice build btw.. this project is the perfect example of what every 86 owner dreams of doing.. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
May 23, 2010 - 2:52 PM
update today May 22
my 3rd gen 3sgte fuel rail came in its bored out by ats racing ![]() after cutting and grinding i got a steel feed line from another fuel rail ![]() here you go dual feed rail ![]() and i picked up my rebuilt lsd with weir performance and also installed my new ring and pinion for my turbo set up ![]() its good i had the lsd rebuilt one of my springs broke inside ![]() installed it this sh$$t is heavy using only my arms as a lift but worked out fine ![]() installed the driveshaft ![]() intalled the calipers rotors brake lines ![]() thank god done again!!! for the second time This post has been edited by 3sgelevin: May 23, 2010 - 2:59 PM |
| Lo-Fi Version | Time is now: August 28th, 2026 - 8:43 AM |
