May 21, 2010 - 2:38 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
Not sure wat happened I made a turn into my work no bumb or nothing amd my tires lost power my engine still runs fine and my tranny but iwhener I try. To move the car it grinds not the tranny I'm thinking the axle maybe not sure too dark to try and look.
May 21, 2010 - 2:42 AM
Not sure wat happened I made a turn into my work no bumb or nothing amd my tires lost power my engine still runs fine and my tranny but iwhener I try. To move the car it grinds not the tranny I'm thinking the axle maybe not sure too dark to try and look. The grinding sound is coming from the ddrivers side |
May 21, 2010 - 4:53 AM
popped axle, when was the last time the tranny oil got changed or measured.
May 21, 2010 - 5:06 AM
May 21, 2010 - 5:53 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 22, '04 From FL Currently Offline Reputation: 1 (100%) |
if you hurt 1 axle then other one should still have power to it. If neither of your front wheels even attempts to spin I think your problem is not an axle. I am thinking you may have an issue with torque converter or transmission.
I assume your car revs up but nothing happens right? -------------------- Captain Pessimist
May 21, 2010 - 6:01 AM
if you hurt 1 axle then other one should still have power to it. If neither of your front wheels even attempts to spin I think your problem is not an axle. I am thinking you may have an issue with torque converter or transmission. I assume your car revs up but nothing happens right? Yes it revs but. It kinda jerks like it wants to move but can't neither tire moves |
May 21, 2010 - 9:13 AM
finally got underneath and it is the axle lame....
May 21, 2010 - 9:14 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
if your axle broke, the other wheel isn't going to pull.
it could be that your cv joint broke. or your clutch is done for. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
May 21, 2010 - 12:25 PM
are you auto or manual
May 21, 2010 - 1:13 PM
May 21, 2010 - 1:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
They pretty easy to put in, only odd tool you need is for the axle nut. Rest is stardard sockets, and a pry bar. Oh and the fluid to refill the trans =P
May 21, 2010 - 1:41 PM
They pretty easy to put in, only odd tool you need is for the axle nut. Rest is stardard sockets, and a pry bar. Oh and the fluid to refill the trans =P sounds easy but im currently lacking the confidence.... to do so even though i should put the chiltons that i just got to good use but on the other hand its more expensive to tow it home than what im paying... mechanic is a block away from work |
May 21, 2010 - 2:33 PM
They pretty easy to put in, only odd tool you need is for the axle nut. Rest is stardard sockets, and a pry bar. Oh and the fluid to refill the trans =P sounds easy but im currently lacking the confidence.... to do so even though i should put the chiltons that i just got to good use but on the other hand its more expensive to tow it home than what im paying... mechanic is a block away from work Ah, not a bad deal then. Did my passenger not to long ago, only part that really sucked was the boot was blown and grease was everywhere =/ |
May 21, 2010 - 3:19 PM
They pretty easy to put in, only odd tool you need is for the axle nut. Rest is stardard sockets, and a pry bar. Oh and the fluid to refill the trans =P sounds easy but im currently lacking the confidence.... to do so even though i should put the chiltons that i just got to good use but on the other hand its more expensive to tow it home than what im paying... mechanic is a block away from work Ah, not a bad deal then. Did my passenger not to long ago, only part that really sucked was the boot was blown and grease was everywhere =/ ahh sux sorry to hear dat. well at least today hasnt been all bad finally got some good news.... |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 9:16 AM |
