> Steering wheel shaking like crazy?
post May 21, 2010 - 8:17 PM
mkernz22
Joined May 10, '10
From MA
Alright, so pretty much when ever I am driving, the steering wheel shakes like crazy.
Even with two hands on the wheel trying to control it, there is so much vibration.
I know my tires are getting pretty low, but they can last a couple more months.
I'm not sure if anyone else has had this problem, but do you think it's the wheel bearings, unbalanced tires/rims, or just low treads?
The car pulls to the right when I let go of the steering wheel too.
Please help me out!
post May 21, 2010 - 8:32 PM
blu94gt
Joined Mar 23, '05
From Kansas City
Constant shaking would make me think that you have a bent wheel or hub, or a VERY BADLY worn tire (like flat spotted from locking up the brakes or something). A tire/wheel that's out of balance will usually be pretty mild and have a certain speed that it's noticeable at. My tires are worn very unevenly and are very noisy, but my I still don't get much feedback thru the steering wheel.
My Miata had a bent wheel, that steering wheel was always shaking like crazy until I put new rims on the car.
1999 Celica GT
post May 21, 2010 - 8:38 PM
mkernz22
Joined May 10, '10
From MA
I don't have any bent wheels, I checked that right off the bat. The tires are worn a lot near the out edge of the treads, but the middle seems to be decent.
When I'm doing about 40mph on the road, the feedback isn't too bad cause I don't notice it half the time, but when I'm on the highway doing about 80-85mph, the feedback is unbearable and it shakes like f***ing crazy! When I replaced the brake pads not to long ago, both front sides had uneven wear. The driver's side had more wear on the inside pad than outside, and the passenger side had more wear on the outside than inside pad. Bad wheel bearings possibly?
post May 21, 2010 - 10:05 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE (Keiri @ May 21, 2010 - 7:34 PM) *
I found out that I need new strut mounts...
After what I've spent on this strut/spring replacement I have to admit that the old guys were right; I should have sprung a little more and just gotten coilovers. wink.gif
QUOTE (mkernz22 @ May 21, 2010 - 8:38 PM) *
More wear on the inside pad is pretty typical on any car. I've never seen bearings cause an issue like that without giving other warning signs such as loud growling noises in corners, scraping, screeching sounds. I would think you would have noticed other problems before bearings cause that much wheel play.
Since you say you notice it more at highway speed I'm going to lean back towards the smaller issue of out of balance/worn tires.
1999 Celica GT
post May 21, 2010 - 10:11 PM
I second that. My tires were (they're getting replaced now) insanely crappy. The previous owner (I bought the wheels used with tires) was a moron and didn't have the tires rotated frequently, and possibly not balanced, so they were cupped like crazy. It's not very noticeable at city speeds, but at highway speeds the wheel shaked quite badly. Get your tires replaced.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
mkernz22
Joined May 10, '10
From MA
I'm hoping it's just the worn out and unbalanced tires, once I save $900 for some 17" Konig Zero's w/ tire package, hopefully it won't be as bad.
post May 21, 2010 - 10:54 PM
Bigblock
Joined Feb 14, '09
From Mid West
Seperated belts in the tire(s) maybe?
Is there something like a wobble in the front at slower tomedium speed, like from a stop to about 30 MPH?
post May 21, 2010 - 11:10 PM
D-Man
Joined Jan 18, '08
From Houston
TIRES man TIRES! from this post, i say you need new TIRES!
CLICKY should be of service to your direct needs.
Damn D-Man - most impressive.
post May 22, 2010 - 11:15 AM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
I would lean more towards a bent rim than tires. An easy way to check is swap your wheels front to back and see if it changes everything
ST205 Crew represent
Challenge Accepted
post May 22, 2010 - 4:48 PM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
Just a FYI, I would take care of this as soon as possible. I have found over my years as a mechanic that if you drive too long with out of balance wheels you significantly increase the speed of wear on your steering/suspension and you will find more rattles popping up in your dash etc. To put it simply, it just shakes things apart over time(think of it like erosion), some cars are more susceptible to this than others. Plus its uncomfortable to drive a car with a jackhammer for a steering wheel.
post May 23, 2010 - 11:56 AM
mkernz22
Joined May 10, '10
From MA
I've rotated the tires a couple weeks ago, and there was really no difference. Both the front and back have the same amount of wear, well pretty close to it.
Nothing wobbles except for the steering wheel. When I slow down, the steering wheel stops wobbling, but say if slam my pedal to the ground and take off from a dead stop, the wheel shakes like freaking crazy.
post May 23, 2010 - 2:46 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
I was about to post something asking a similar question b/c my steering wheel vibrates above 75mph. Nothing too crazy, I've gotten used to it, but now I know what I can do to fix it! Thanks!
June '12 COTM
'95 AT200
post May 27, 2010 - 11:55 PM
nnesto
Joined Apr 23, '06
From Crestline, CA
I'm probably way off base here, but check your cv boots. might be your cv joints going bad from a cracked boot.
post May 28, 2010 - 12:03 AM
Stambo
Joined Apr 23, '08
From Muskego,Wi
Honestly, check out all your suspension, tie rods, wheel bearings, ball joints to while your at it. The tires would have to be insanely chopped to do something that crazy. You can just rub your hand across the tires and feel that they are out of round. If they arn't terrible, its something else for sure.
2nd Gen 3s-gte.... It lives!
97celiman
post May 28, 2010 - 10:05 AM
schmooot
Joined Sep 29, '09
have you done any major hard braking lately...like hard enough to skid all 4 wheels for a few feet?
Challenge Accepted
post Jun 1, 2010 - 6:19 PM
mkernz22
Joined May 10, '10
From MA
the tires aren't chopped or anything like that and i accidentally skidded all 4 tires once cause i didnt notice a stop sign that was in the middle of no where once, but it shook and whatnot wayyy before that happened. I'm getting new tires soon. I'm having them balanced and i am going to get an alignment as well. If nothing changes after all that and the steering wheel is shaking, I'll check more in depth on the whole suspension thing.
post Jun 5, 2010 - 5:35 PM
mkernz22
Joined May 10, '10
From MA
also, one other thing i noticed is that the owner before me put new calipers and drilled rotors, and when i take the wheels off, the rotors just wobble.
i would sort of think that they should be mounted somehow so they don't wobble, but as for now, the only thing holding them on when the wheels are off are the calipers/brake pads. braking is smooth on it, so i am not sure if that is much of a problem or not?
post Jun 5, 2010 - 7:51 PM
schmooot
Joined Sep 29, '09
QUOTE (mkernz22 @ Jun 5, 2010 - 3:35 PM) *
that's fine. The only thing that holds the rotors on is the caliper and the fact that it is mashed between the wheel and hub doesn't hurt either. It should be fully loose once the caliper is removed
Challenge Accepted
post Jun 7, 2010 - 3:54 PM
tadastoppp
Joined Oct 6, '09
From Lithuania
I also have a similar problam. When i drive - everything is ok, but when i am at big speed and i push brakes my car starts shaking. Where to look for problems? Tyres are good, wheels are balanced, also new brake pads installed.
post Jun 7, 2010 - 7:52 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (tadastoppp @ Jun 7, 2010 - 10:54 AM) *
that points to warped brake rotors.
Lo-Fi Version Time is now: September 8th, 2026 - 8:08 AM
