May 30, 2010 - 11:26 AM
Enthusiast Joined Feb 25, '07 From Columbus, Ohio Currently Offline Reputation: 0 (0%) |
I'm replacing my factory power antenna with an aftermarket one. I have it mounted but the question I have is how do I hook up the wires. There are 6 wires running to the factory antenna relay and 2 running to the antenna. My aftermarket only has 3 wires, black for ground, red for power and blue for switched.
Do I have to use the factory relay, not sure if it does anything else, especially since it has 6 wires? If not what wires do I tap into, I figure I can put the ground directly to the body, but which wires are the power and switch from the radio. It may be helpful if anyone had a wiring diagram. |
Jun 2, 2010 - 10:31 PM
Enthusiast ![]() Joined Jun 9, '09 From Saint Louis Currently Offline Reputation: 0 (0%) |
Jun 29, 2010 - 6:36 PM
Enthusiast Joined Jun 29, '10 From mqq6@cox.net Currently Offline Reputation: 0 (0%) |
I just put in a new antenna and used the following wires on my 1999 Celica
White/black -- ground blue/orange (could be blue/red - I am color blind) - 12 volt continuous black - 12 volt when radio is on ---------------------------- When I installed my power antenna, I cut the connector and the power windows stopped working. This is because power to the windows from the 12 v (key on) occurs in the power antenna harness. To get it back working connect grey - 12 volt when key is on blue/red (could be blue/orange - I am still color-blind) - connects to power windows I suggest that you use a voltmeter to verify colors since I am color-handicapped!!!! |
| Lo-Fi Version | Time is now: July 30th, 2026 - 3:59 PM |
