> car stall/erratic idle
post Jun 5, 2010 - 11:17 AM
SleekCelica
Joined Mar 28, '10
From Columbia, South Carolina
So when I first bought this car, it had a really bad erratic idle, that would drop down to 0 and bounce right back up in a matter of a second, and keep doing this. It would flicker, and then stall. It's not fuel related. It'll actually stall when I'm driving and then not start back up. I replaced the ignition coil and all was fine. Now, three months later, it's doing this again >:( What do you guys think? It's throwing a 12, 13, and 41 codes. Could these all be related to the 41 (TPS?)
1994 Celica GT, coupe, 5 speed.
Front strut brace, cherrybomb glasspack, intake.
- SleekCelica   car stall/erratic idle   Jun 5, 2010 - 11:17 AM
- - presure2   distributor.   Jun 5, 2010 - 11:35 AM
- - SleekCelica   Do you think so? I figured 12 and 13 were leaning ...   Jun 5, 2010 - 11:46 AM
- - Keiri   Ok, so normally when I start my car it revs to ~ 1...   Jun 6, 2010 - 10:03 AM
|- - stephen_lee   clean your throttle body throughly with TB or CARB...   Jun 7, 2010 - 9:21 AM
- - SleekCelica   pull a spark plug, attached to a wire, ground it o...   Jun 6, 2010 - 10:08 AM
- - stephen_lee   u wont get a spark with the ignitor unplugged   Jun 6, 2010 - 4:17 PM
- - SleekCelica   oops, didn't mean to put that, was thinking ab...   Jun 6, 2010 - 8:45 PM
- - Keiri   QUOTE (stephen_lee @ Jun 7, 2010 - 10...   Jun 7, 2010 - 12:01 PM
- - stephen_lee   keiri, yes the line above it directed at you. cle...   Jun 7, 2010 - 1:25 PM
- - Keiri   QUOTE (stephen_lee @ Jun 7, 2010 - 2...   Jun 7, 2010 - 2:35 PM
- - SleekCelica   Reviving an old thread- my car's still doing t...   Jul 3, 2010 - 2:42 PM
- - presure2   its the distributor, like i said in the first repl...   Jul 3, 2010 - 5:16 PM
- - SleekCelica   Now, to be sure, and I'm not doubting you in t...   Jul 3, 2010 - 5:46 PM
|- - Johnnyny   QUOTE (SleekCelica @ Jul 3, 2010 - 6...   Jul 3, 2010 - 5:48 PM
- - SleekCelica   I really hope this is the problem.... will one off...   Jul 3, 2010 - 5:51 PM
|- - Johnnyny   QUOTE (SleekCelica @ Jul 3, 2010 - 6...   Jul 3, 2010 - 5:52 PM
- - SleekCelica   Cool, I'll let you guys know how this works ou...   Jul 3, 2010 - 6:15 PM
- - SleekCelica   Bought a distributor from checkers auto in oklahom...   Jul 21, 2010 - 3:33 PM
|- - Johnnyny   QUOTE (SleekCelica @ Jul 21, 2010 - 4...   Jul 21, 2010 - 3:42 PM
|- - stephen_lee   totally found you on the toyota fan page on facebo...   Jul 21, 2010 - 5:04 PM
- - SleekCelica   That's awesome. I love this car that much that...   Jul 21, 2010 - 6:21 PM
- - SleekCelica   I can't find a new one, so I suppose i'm s...   Jul 22, 2010 - 9:05 AM
- - rave2n   http://cgi.ebay.com/ebaymotors/92-93-94-95...sQ5fA...   Jul 22, 2010 - 10:50 AM
- - SleekCelica   I'm going to end up buying one from autozone. ...   Jul 22, 2010 - 11:21 AM
- - SleekCelica   So... the distributor didn't fix it. Still doe...   Jul 22, 2010 - 8:31 PM
- - rave2n   When mine was like this, it ended up being the dis...   Jul 22, 2010 - 8:55 PM
- - SleekCelica   At this point, I've pretty much narrowed it do...   Jul 22, 2010 - 9:27 PM
- - Remy   QUOTE (SleekCelica @ Jun 5, 2010 - 11...   Jul 22, 2010 - 9:53 PM
- - SleekCelica   I'm not going to just start replacing parts. I...   Jul 23, 2010 - 8:41 AM
- - SleekCelica   And now it's not throwing code 12. So I just h...   Jul 25, 2010 - 8:47 AM
|- - presure2   QUOTE (SleekCelica @ Jul 25, 2010 - 9...   Jul 25, 2010 - 9:03 AM
- - SleekCelica   Alright, I'll try that. Thanks!   Jul 25, 2010 - 9:08 AM
- - SleekCelica   continuity test checks out great for every wire, i...   Jul 25, 2010 - 1:40 PM
- - stephen_lee   if your GT is auto i have an ECU hanging around il...   Jul 26, 2010 - 11:54 AM
- - SleekCelica   standard, but I already ordered one. I popped open...   Jul 26, 2010 - 1:06 PM
|- - rave2n   QUOTE (SleekCelica @ Jul 26, 2010 - 1...   Jul 26, 2010 - 7:36 PM
- - stephen_lee   my 92 lexus had the same problem.. electrolytic ca...   Jul 26, 2010 - 9:41 PM
- - SleekCelica   Yeah, I'm glad that I have finally found the p...   Jul 27, 2010 - 8:08 AM
- - SleekCelica   I don't want to jump the gun on this, but I go...   Jul 29, 2010 - 3:52 PM
|- - Icewata   QUOTE (SleekCelica @ Jul 29, 2010 - 4...   Jan 16, 2011 - 4:08 PM
|- - Icewata   QUOTE (SleekCelica @ Jul 29, 2010 - 3...   Oct 20, 2011 - 1:06 PM
- - 95celgt   i have a very similar problem right now, its been ...   Jan 16, 2011 - 9:18 PM
|- - presure2   QUOTE (95celgt @ Jan 16, 2011 - 9:18...   Jan 17, 2011 - 10:44 AM
- - 95celgt   nice thanks manny, i put a 92 5sfe in my 95 and it...   Jan 18, 2011 - 7:08 PM
- - xrav22   QUOTE (95celgt @ Jan 18, 2011 - 8:08...   Jan 22, 2011 - 8:39 PM
Lo-Fi Version Time is now: September 12th, 2026 - 6:53 AM
