Jun 5, 2010 - 11:17 AM
Enthusiast ![]() ![]() Joined Mar 28, '10 From Columbia, South Carolina Currently Offline Reputation: 1 (100%) |
So when I first bought this car, it had a really bad erratic idle, that would drop down to 0 and bounce right back up in a matter of a second, and keep doing this. It would flicker, and then stall. It's not fuel related. It'll actually stall when I'm driving and then not start back up. I replaced the ignition coil and all was fine. Now, three months later, it's doing this again >:( What do you guys think? It's throwing a 12, 13, and 41 codes. Could these all be related to the 41 (TPS?)
-------------------- ![]() 1994 Celica GT, coupe, 5 speed. Front strut brace, cherrybomb glasspack, intake. |
SleekCelica car stall/erratic idle Jun 5, 2010 - 11:17 AM
presure2 distributor. Jun 5, 2010 - 11:35 AM
SleekCelica Do you think so? I figured 12 and 13 were leaning ... Jun 5, 2010 - 11:46 AM
Keiri Ok, so normally when I start my car it revs to ~ 1... Jun 6, 2010 - 10:03 AM
stephen_lee clean your throttle body throughly with TB or CARB... Jun 7, 2010 - 9:21 AM
SleekCelica pull a spark plug, attached to a wire, ground it o... Jun 6, 2010 - 10:08 AM
stephen_lee u wont get a spark with the ignitor unplugged Jun 6, 2010 - 4:17 PM
SleekCelica oops, didn't mean to put that, was thinking ab... Jun 6, 2010 - 8:45 PM
Keiri QUOTE (stephen_lee @ Jun 7, 2010 - 10... Jun 7, 2010 - 12:01 PM
stephen_lee keiri, yes the line above it directed at you.
cle... Jun 7, 2010 - 1:25 PM
Keiri QUOTE (stephen_lee @ Jun 7, 2010 - 2... Jun 7, 2010 - 2:35 PM
SleekCelica Reviving an old thread- my car's still doing t... Jul 3, 2010 - 2:42 PM
presure2 its the distributor, like i said in the first repl... Jul 3, 2010 - 5:16 PM
SleekCelica Now, to be sure, and I'm not doubting you in t... Jul 3, 2010 - 5:46 PM
Johnnyny QUOTE (SleekCelica @ Jul 3, 2010 - 6... Jul 3, 2010 - 5:48 PM
SleekCelica I really hope this is the problem.... will one off... Jul 3, 2010 - 5:51 PM
Johnnyny QUOTE (SleekCelica @ Jul 3, 2010 - 6... Jul 3, 2010 - 5:52 PM
SleekCelica Cool, I'll let you guys know how this works ou... Jul 3, 2010 - 6:15 PM
SleekCelica Bought a distributor from checkers auto in oklahom... Jul 21, 2010 - 3:33 PM
Johnnyny QUOTE (SleekCelica @ Jul 21, 2010 - 4... Jul 21, 2010 - 3:42 PM
stephen_lee totally found you on the toyota fan page on facebo... Jul 21, 2010 - 5:04 PM
SleekCelica That's awesome. I love this car that much that... Jul 21, 2010 - 6:21 PM
SleekCelica I can't find a new one, so I suppose i'm s... Jul 22, 2010 - 9:05 AM
rave2n http://cgi.ebay.com/ebaymotors/92-93-94-95...sQ5fA... Jul 22, 2010 - 10:50 AM
SleekCelica I'm going to end up buying one from autozone. ... Jul 22, 2010 - 11:21 AM
SleekCelica So... the distributor didn't fix it. Still doe... Jul 22, 2010 - 8:31 PM
rave2n When mine was like this, it ended up being the dis... Jul 22, 2010 - 8:55 PM
SleekCelica At this point, I've pretty much narrowed it do... Jul 22, 2010 - 9:27 PM
Remy QUOTE (SleekCelica @ Jun 5, 2010 - 11... Jul 22, 2010 - 9:53 PM
SleekCelica I'm not going to just start replacing parts. I... Jul 23, 2010 - 8:41 AM
SleekCelica And now it's not throwing code 12. So I just h... Jul 25, 2010 - 8:47 AM
presure2 QUOTE (SleekCelica @ Jul 25, 2010 - 9... Jul 25, 2010 - 9:03 AM
SleekCelica Alright, I'll try that. Thanks! Jul 25, 2010 - 9:08 AM
SleekCelica continuity test checks out great for every wire, i... Jul 25, 2010 - 1:40 PM
stephen_lee if your GT is auto i have an ECU hanging around il... Jul 26, 2010 - 11:54 AM
SleekCelica standard, but I already ordered one. I popped open... Jul 26, 2010 - 1:06 PM
rave2n QUOTE (SleekCelica @ Jul 26, 2010 - 1... Jul 26, 2010 - 7:36 PM
stephen_lee my 92 lexus had the same problem.. electrolytic ca... Jul 26, 2010 - 9:41 PM
SleekCelica Yeah, I'm glad that I have finally found the p... Jul 27, 2010 - 8:08 AM
SleekCelica I don't want to jump the gun on this, but I go... Jul 29, 2010 - 3:52 PM
Icewata QUOTE (SleekCelica @ Jul 29, 2010 - 4... Jan 16, 2011 - 4:08 PM
Icewata QUOTE (SleekCelica @ Jul 29, 2010 - 3... Oct 20, 2011 - 1:06 PM
95celgt i have a very similar problem right now, its been ... Jan 16, 2011 - 9:18 PM
presure2 QUOTE (95celgt @ Jan 16, 2011 - 9:18... Jan 17, 2011 - 10:44 AM
95celgt nice thanks manny, i put a 92 5sfe in my 95 and it... Jan 18, 2011 - 7:08 PM
xrav22 QUOTE (95celgt @ Jan 18, 2011 - 8:08... Jan 22, 2011 - 8:39 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 12th, 2026 - 5:35 AM |
