> Rubbing Noise, From front wheel well
post Jan 16, 2003 - 9:02 PM
BlackBeauty
Joined Jan 12, '03
From New Zealand
Anybody got this as well?
My (100% standard) 96 Celica makes a rubbing noise from front wheel well (not sure left or right or both) when it's in full lock, like in doing U-turns.
I've checked the tires but they are not rubbing against anything (well....nothing that I know of)
post Jan 17, 2003 - 2:22 AM
Guest_Matthew_*
don't turn to full lock anymore. Other than, I would suggest taking off your tires to see if there is something wrong under there.
post Jan 17, 2003 - 2:25 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
i've had the same thing. looks like the plastic wheel well liner bowed in a little on mine. took a heat gun to it the pushed and held it till it cooled. no problems since.
post Jan 17, 2003 - 4:22 AM
BlackBeauty
Joined Jan 12, '03
From New Zealand
Yeah, on further check I found out that the plastic wheel well liner (on the right side) is slightly bowed. Also the same case on the plastic tray underneath front bumper. (Bad manufacturing?)
Thank's for the advice, AudioFreak.
Anyway, if anybody has the same problem but different cause, please tell me about it. Might be better to check really thoroughly for the cause.
Thanks
post Jan 17, 2003 - 2:54 PM
JiGGa
Joined Dec 20, '02
I had the same problem jsut before I was making a U to get to a parking space and it made this sound like the front wheel was touching the front bumper. What can I do the fix it?
Lo-Fi Version Time is now: September 1st, 2026 - 5:20 PM
