Jun 17, 2010 - 5:01 AM
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
Now I know not everyone has had wheel bearing issues yet but when you do, watch out haha. A while back I found out I had a bad wheel bearing (my fault never checking for play etc) so I took the hub out and went to press a new one in realising the flange on top needed to be changed also ($150 from toyota) so all seems simple so far...30km later, noises again, I was thinking it was just the axle nut was not the right torque setting, find out the bearing seized, I couldn't be bothered to put a new one in so I payed someone to do it, 50km after the bearing, it was ruined again and had play, the flange was also destroyed. so $250 later I decided to find a hub in a wreckers, no problem on that side whatsoever since.
Knowing they often go one after the other I checked for play regularly and listened out for noises on the other side, but all seemed well until a few days ago it was making noise, I took it off and the nut was finger tight, did up to right torque settings and was fine until a day later, but didn't show any play yet, took it apart to get it pressed in and the flange moved up and down :s and had a little play. I'm hoping I will have less problems as I got there early this time round, after finding one competent mechanic he told me how celicas always have that horrible problem and the flange and hubs get eaten away when they have much play. Not only this, when I had the first one go bad, it didn't make any noises at all and didn't show any signs at the hub of damage, and every incompetent mechanic said the hub was fine when I'd question it. Is this a problem on all cars or do our cars just have a horrible design? I've just generally never heard of people having problems, ive heard they make noises, you get them fixed quick and they are fine. Also to get a hub ($450 AUD) Flange ($150 AUD) and wheel bearing from toyota ($120 AUD) that is a lot of money for a bad wheel bearing, lucky for me I found a wreckers This post has been edited by Euphoria: Jun 17, 2010 - 5:06 AM |
Euphoria Wheel bearing problems Jun 17, 2010 - 5:01 AM
soulshadow I've never owned my Celica long enough for it ... Jun 17, 2010 - 10:00 AM
Euphoria I'd say its a lot to do with how long you driv... Jun 17, 2010 - 10:28 AM
soulshadow If you run over lots of pot holes and hit the curb... Jun 17, 2010 - 2:24 PM
Remy I have almost 200k on the chassis and still have t... Jun 17, 2010 - 4:16 PM
azian_advanced QUOTE (Remy @ Jun 17, 2010 - 4:16 PM... Jun 17, 2010 - 5:06 PM
OOBE QUOTE (Remy @ Jun 17, 2010 - 3:16 PM... Jun 26, 2010 - 2:17 PM
azian_advanced dealers recommend replacing the hubs at the same t... Jun 17, 2010 - 4:51 PM
Remy ^^^ Correct both axles are new not original, I... Jun 17, 2010 - 5:31 PM
Euphoria well both my bearings went out at about 230-240k a... Jun 17, 2010 - 10:25 PM
Tech-Nics same thing happened to me. Even to this day i stil... Jun 17, 2010 - 11:56 PM
Euphoria finally someone who has had my problems haha.
tur... Jun 18, 2010 - 12:09 AM
Euphoria QUOTE (OOBE @ Jun 26, 2010 - 3:17 PM... Sep 16, 2010 - 7:29 AM
whatthe ^ and spacers haha Sep 16, 2010 - 7:32 AM
JustinCapps i learned this all the hard way about 3 weeks ago.... Sep 16, 2010 - 10:27 PM
stiph1nr 94 gt 191k
i replaced wheel bearing + driver axe... Sep 17, 2010 - 12:14 PM
cyberblader1130 That seems strange to me, ive changed both of my w... Sep 17, 2010 - 2:23 PM
Euphoria People don't seem to understand, if you change... Sep 20, 2010 - 1:45 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 28th, 2026 - 4:22 PM |
