Aug 2, 2010 - 8:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
yay!
Aug 9, 2010 - 8:26 PM
Enthusiast ![]() Joined Nov 11, '08 From boston Currently Offline Reputation: 0 (0%) |
Hmm figure I update this. Ok so yesterday I began to try and figure out why my car smokes like a train after it runs for a few minutes. I know since the motor has seen no mileage the rings aren't seated but damn, its a lot of smoke. Pulled the turbo and all behold the charge pipes are full of oil, my exhaust has oil seeping right through it. That explains some of the smoke, now my turbo has no mileage but I did start the car with it installed a few times and oil pressure is well over 100 psi at 3500 rpm. Pretty sure that killed it, anyway added a few restrictors and began to rethink my return since my scavenge pump should handle that oil pressure no problem. So something is wrong.
Anyway instead of trying to eliminate things I dumped my whole return setup, do it again and if it still smokes try to rebuild the turbo before Thursday ![]() ![]() ![]() ![]() -------------------- I am addicted to Turbos
SOLD |
Aug 10, 2010 - 5:27 PM
Enthusiast Joined Oct 16, '09 From Webster MA Currently Offline Reputation: 0 (0%) |
well hopefully its just the turbo seal popping out or something, but once i get my license back we gotta see how the supra runs against the d-series, every one says my car is fast but to me its not
Aug 11, 2010 - 7:15 AM
well hopefully its just the turbo seal popping out or something, but once i get my license back we gotta see how the supra runs against the d-series, every one says my car is fast but to me its not Sure y not, Only thing is that obviously your drivetrain is better than mine, your huge gears and higher top speed will "eventually" catch up to me -------------------- I am addicted to Turbos
SOLD |
Aug 11, 2010 - 12:57 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
What tranny you using?
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Aug 14, 2010 - 7:00 PM
Stock civic VX transmission. The cheapest trans honda has but best for turbo due to the longer gears.
Brought it to the dyno but my turbo blew up, follow the pics and you should figure out what going on. I will do a write up later once I get more done ![]() ![]() ![]() ![]() Turbo exploded ![]() Time to rebuild ![]() ![]() Assembly ![]() ![]() Balancing ![]() ![]() Finished ![]() ![]() Some more wrench time and back to dyno to try again This post has been edited by Cevax: Aug 14, 2010 - 7:02 PM -------------------- I am addicted to Turbos
SOLD |
Sep 4, 2010 - 9:18 AM
Well when i put the turbo back on the car stop smoking, but it was just because the oil started collecting in the exhaust housing and wasn’t burning right away. The turbo still leaked,, The thing with Chinese turbos are the bearings, seals are extremely low quality. The turbines and compressors are fine since they are just backward engineered from real turbos. A turbonetic turbo will survive up to 85psi of oil pressure and a stock dsm turbo will run for quite a bit with a blocked off return. A Chinese replica is recommended 7-15 psi of oil pressure, which alone says a lot about quality. So they just have no room for error, if somebody is going to use one, the setup must be done perfectly since those turbo wont survive much.
Anyway, scraped my turbo setup, bought a new manifold that’s in the way and going to match it with a tial. Bought these snails and just have to decide what to run. They are both a bit big and will slow down my spool, but I can push my motor past 500 horses either one of these. ![]() -------------------- I am addicted to Turbos
SOLD |
Sep 4, 2010 - 6:26 PM
Enthusiast ![]() ![]() ![]() Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) |
Good info and write up. What turbos are those?
-------------------- "God created turbo lag to give V8's a chance"
Sep 4, 2010 - 6:37 PM
Good info and write up. What turbos are those? The turbonetic is a t3/t04e while the garrett is a 57trim m24. They are both in good shape and trying to decide which to go with. One is going to be a backup that way I aint off the road if something happens. -------------------- I am addicted to Turbos
SOLD |
Sep 4, 2010 - 8:41 PM
Well I think Garrett says the 57 trim m24 flows 53 lbs/min. Couldn't find anything charts on the turbonetics though. Are they both ball bearing?
This post has been edited by Nartanian: Sep 6, 2010 - 5:11 PM -------------------- "God created turbo lag to give V8's a chance"
Sep 4, 2010 - 8:47 PM
Well I think Garrett says the 57 trim m24 flows 53 lbs/min and the turbonetics flows. Couldn't find anything charts on the turbonetics though. Are they both ball bearing? I don't think the turbonetics is ball bearing so its probably at to4b, not sure what it flows. I haven't pulled any of them apart to check the bearing but I would be surprised if the Garrett isn't ball bearing. Garrett is ~678 cfm Turbonetic is ~550-678 cfm NOT SURE Thing is the turbonetic will spool faster This post has been edited by Cevax: Sep 4, 2010 - 9:00 PM -------------------- I am addicted to Turbos
SOLD |
Sep 6, 2010 - 5:12 PM
I'd just go with the Garrett then. Might as well start the fun early. It'd be nice to see dyno graphs on it too. Although I hear garrets are really sensitive when it comes to oil pressure or else they blow.
This post has been edited by Nartanian: Sep 6, 2010 - 5:14 PM -------------------- "God created turbo lag to give V8's a chance"
Sep 18, 2010 - 2:59 PM
I am STILL at it, Just dealing with some personal problems but not giving up yet.
SOLD |
Oct 18, 2010 - 7:03 PM
many things have happend, follow the pics to get an idea.
![]() ![]() ![]() ![]() Got a 70mm TB ![]() ![]() THEN!!!!!!!!!!!!! ![]() ![]() ![]() ![]() So here is a Video below of it all back together again
This post has been edited by Cevax: Oct 18, 2010 - 7:04 PM -------------------- I am addicted to Turbos
SOLD |
Oct 11, 2012 - 8:50 AM
2 Years later
![]() ![]() I have changed everything from the date this post was made, it was bored out, bigger pistons etc etc Also did the entire fuel delivery and air delivery over again. Bigger turbo etc you name it, it was done over again Its at 10psi in first gear, 18 in second, 26 on 3rd and 4th and down to 18 in 5th. I have no power numbers, I tuned it myself and I don't race it so no track numbers. No ebay or chinese parts, everything is now brand name (and I went out of my way to make sure each part is not built in china), and each dug a small hole in my wallet Seriously though the only Chinese thing left is the radiator hoses, will order some saamco ones when I get the chance. The radiator is staying because it actually works better than the mishimoto one This post has been edited by Cevax: Oct 11, 2012 - 9:04 AM -------------------- I am addicted to Turbos
SOLD |
Oct 11, 2012 - 11:44 AM
Enthusiast ![]() ![]() ![]() Joined Feb 14, '09 From Mid West Currently Offline Reputation: 7 (100%) |
Sounds like a fun drive!!
Oct 11, 2012 - 12:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
No air filter?
-------------------- 95 gt coupe, v6 swap weekend toy
Oct 11, 2012 - 12:31 PM
No air filter? Not at the moment until I can get some bends to be able to fit one on. -------------------- I am addicted to Turbos
SOLD |
Oct 11, 2012 - 12:47 PM
Ahh ok.
Good build BTW. Kinda makes me miss working on hondas. But my v6 celi keeps me busy -------------------- 95 gt coupe, v6 swap weekend toy
Oct 11, 2012 - 1:44 PM
Darn backwards engines...
| Lo-Fi Version | Time is now: July 19th, 2026 - 11:42 AM |
