> Air bag replacement, Help with air bag specifics
post Jun 24, 2010 - 11:05 AM
foilman
From Coarsegold, Ca.
I have a 99 convertible and a 99 donor vehicle. Can anyone give me a general idea what I will be up against to replace air bags, sensors, and control unit? I have looked into this a little concerning safety. I do not however know location of sensors and control unit. I think I can swap out deployed units with undeployed from donor vehicle. Vehicle had a front end collision and I have finally gathered up front bumper, crash bar, windshield, misc plastics, etc., plus donor vehicle with driver and passenger side air bags. Sorry for being so wordy, any help will be appreciated, Ron, (foilman) in Fresno.
Replies (1 - 10)
post Jun 24, 2010 - 12:07 PM
richee3
Joined Jun 29, '08
From Denver
For starters, disconnect the negative terminal of your battery, let the car sit a few minutes, hit the brake to drain the rest of the juice, blah blah blah. Driver's side airbag is easy. You'll need a T27 Torx head to get two screws out of the sides of the steering whee. From there, you can take the whole cover and airbag out of the steering wheel and the new one is just plug and play. Passenger side airbag, as I understand it, is a lot more difficult. You have to do everything from the bottom of the dash. I couldn't begin to tell you the process for that. The main control unit is under the center console. That's easy to take out. Two screws under the shift bezel, two bolts in the storage bin, and a plug for the ash tray light. As far as sensors go, again that's something that somebody else will have to help you with. Hopefully this just helps you get started and puts you in the right direction.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 24, 2010 - 1:12 PM
foilman
QUOTE (richee3 @ Jun 24, 2010 - 1:07 PM) *
post Jun 24, 2010 - 1:42 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yes?
QUOTE (foilman @ Jun 24, 2010 - 1:12 PM) *
post Jun 24, 2010 - 1:43 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
I'll try to get you a picture of where the sensors are located in the car; I have the '99 Celica Big Green Book.
Give me till midnight tonight.
Has no more Celicas
post Jun 24, 2010 - 5:09 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
sensors are behind the bumper bolted to the vertical radiator supports. the have yellow wires going to them.
post Jun 24, 2010 - 11:46 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (stephen_lee @ Jun 24, 2010 - 6:09 PM) *
And the images to prove:
Has no more Celicas
post Jul 5, 2010 - 2:22 PM
mkernz22
Joined May 10, '10
From MA
Not to jack the thread, but can anyone give us directions on how to take out the passenger side airbag?!?
I have the same problem.
post Jul 5, 2010 - 9:12 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
u can try to just take the glovebox out but i dout thatll work. its basically going to require pulling the wwhole dash..
post Jul 5, 2010 - 9:34 PM
mkernz22
Joined May 10, '10
From MA
are you seriouss....
post Jul 6, 2010 - 5:01 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
sadly, yes. as i said u may be able to get away with just pulling the glovebox and possibly the evap core...
Lo-Fi Version Time is now: August 28th, 2026 - 4:08 AM
