> Anyone have any thoughts on the quality of this exhaust manifold?
post Jun 30, 2010 - 12:50 AM
zonz540
Joined Jul 3, '09
From UT
http://cgi.ebay.com/ebaymotors/Toyota-Coro...sQ5fAccessories
I need a manifold for my 7a and im looking for one i can just buy. I really dont want to have to have one made....
Any thoughts?
Replies (1 - 16)
post Jun 30, 2010 - 4:09 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
That's a bad quality manifold, regardless of who tells you otherwise. It'll work but don't expect it to last very long. I can sell you my JGS log manifold if you want. I'm not using it. smile.gif
post Jun 30, 2010 - 2:39 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
what size turbo are you using, i can make you one like on my kit?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 16, 2010 - 11:01 AM
rivs
Joined Jan 27, '08
From Mass
What is it about these manifolds that make it poor quality? Are they too thin? Poor welds?
Just wondering.
-rivs
post Jul 16, 2010 - 11:16 AM
Culpable04
Joined Apr 17, '06
From New Jersey
in order to keep cost down and be able to offer them and those low prices they use thin steel, which wont handle the weight and stress of a turbo for too long. they can be made to last longer by using some type of support bracket to help release some of the stress.
post Jul 16, 2010 - 2:43 PM
joehernandez
Joined Aug 5, '06
From San Luis AZ
QUOTE (Smaay @ Jun 30, 2010 - 2:39 PM) *
you can make manifolds?
uhmmm would like to see picture,
i have a 3sgte
post Jul 16, 2010 - 5:59 PM
celica74
Joined Feb 8, '10
From North Carolina
I have the same manifold. If your running external wastegate you have to cut a hole in it for that and then maybe a wideband. Very good quality manifold for the price.
post Jul 19, 2010 - 12:19 AM
zonz540
Joined Jul 3, '09
From UT
QUOTE (OOBE @ Jun 30, 2010 - 3:09 AM) *
How much? And will i have to swap fans?
QUOTE (Smaay @ Jun 30, 2010 - 1:39 PM) *
Again, how much? Im going to run a Garrett T25 60 trim
post Jul 19, 2010 - 9:25 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
why dont you just use the stock manifold if you are using a 3S-GTE. but you want one custom made look in the thread i made about turboing the 7S-FE. it will look similar to that. oh by the way, i think T25 is too small. you want at least a T3. im going to be baking kits with a Garrett T3 super 60 turbo. it spools real fast and is good for 300HP. stay tuned!
post Jul 20, 2010 - 1:13 PM
zonz540
Joined Jul 3, '09
From UT
I have a 7a. My goal is 200-225, so i really dont need a big turbo. I doubt ill even hit that, considering what most people have actually gotten out of their 7a's prior, not to mention im going on stock internals.
I just need a manifold that will bolt up and support my turbo. If you (anyone) can make a decent one, let me know a price.
post Jul 21, 2010 - 4:53 PM
celica74
Joined Feb 8, '10
From North Carolina
Good luck going for 200-225, i mean that in the nicest way possible. Looking through what DCW and stef did with there setups is alot of work(internals, emange, all that good stuff, not to mention the turbos that they chose. Its deffinetly possible, dont get me wrong, the 7a crank will handle 300 if the motor is built right. You can either go cheap rout with the manifold (4afe manifold) or a little more pricey(custom). Either way its a manifold and it still carries exhaust gases. Look and quality are the only factors through.
post Jul 22, 2010 - 10:01 AM
krom8
Joined Jun 17, '10
From Frankfort Kentucky
There is a guy with an AE92 who's using a 7agte setup and pushing 500hp on the stock crank and rods connected with ARP rod bolts. His biggest problem so far has been that he can't get a transmission to hold up under all that stress. I know this doesn't have anything to do with the manifold in question but since the topic of bottom ends popped up I thought I'd chime in. Here's the guy's build thread http://forums.toyspeed.org.nz/viewtopic.ph...asc&start=0
I'm sorry, he's updated to forged internals since the last time I checked. I do still believe it's the stock crank.
This post has been edited by krom8: Jul 22, 2010 - 10:27 AM
post Jul 22, 2010 - 10:53 AM
nik
Joined Sep 30, '02
QUOTE (celica74 @ Jul 21, 2010 - 2:53 PM) *
totally agree i have been down the 7afte road with some ok numbers ( see the how to's for my build and dyno)
And then later when i built my 7agte the right way and hit 392 whp on 92 pump gas ( see 7agte build thread on here for more info)
post Jul 22, 2010 - 11:00 AM
nik
Joined Sep 30, '02
QUOTE (krom8 @ Jul 22, 2010 - 8:01 AM) *
my 7agte 392 whp is on a stock crank ( balanced) which is around 450 @ the flywheel
post Jul 22, 2010 - 11:04 AM
nik
Joined Sep 30, '02
post Jul 22, 2010 - 3:01 PM
zonz540
Joined Jul 3, '09
From UT
I know it takes some work, but 200 is a very achievable number if you put as much into it as it needs. Im not so much concerned about that as just adding a little something to the 7a. Its so gutless sometimes, especially when it gets above 90 degrees out... Id like to hit the gas and actually go somewhere once in a while above 2nd gear...
Like i said, im going on stock internals, so 200 would be nice, but isnt a definite goal, ill take what i can get. I just want a little more out of my ST.
And again, if someone has a decent manifold that will bolt up to the 7a, ill take it off of your hands. Otherwise, ill prob just end up buying an ebay one and hacking and welding it at a friends exhaust shop till it fits my needs.
Thanks for the input!
post Jul 26, 2010 - 1:46 AM
cadee
Joined Jul 26, '10
From Cebu City
QUOTE (zonz540 @ Jun 30, 2010 - 1:50 AM) *
Any thoughts?
I have found that in amazon before but I forgot that specific url.
Lo-Fi Version Time is now: September 13th, 2026 - 1:07 PM
